Old 01-24-2005, 03:40 AM
henrymv henrymv is offline
90 Accord EX Coupe
Does anyone know how to tighten the screw on the side (door) window. It is the flat black disc on the upper left hand corner of the driver side window. I can only get it finger tighten, but it vibrates loose and these things cost $20 to replace.
Old 01-24-2005, 12:51 PM
mpumas mpumas is offline
Re: 90 Accord EX Coupe
Glue it in with rubber contact cement. If you need to remove, laquer thinner will soften it.
Old 01-24-2005, 04:33 PM
Problem is, it requires for it to be screwed into....and i can only get it screwed in half way....there has to be a way to fully get it screwed in....any ideas???
Old 01-24-2005, 05:12 PM
lorunner lorunner is offline
The only way is to remove the window.
You can try to remove the black channel it rides in. Next to the groove there is a rubber strip that has double stick tape on it. Take the strip off and there will be screws behind it. If you take the screws out you can work that track out of the door.
I must warn you thats its not an easy job.
Old 01-24-2005, 05:48 PM
ok, thanks.....i will try it.....thanks for the input!!
