Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 01-24-2005, 12:48 AM
leon hefner leon hefner is offline
tach bounces stalls
hello i hav a 95 aurora tachometer bounces engine will stall out while driving. i love my car. help tach will bounce erratically usually at 2000 rpm then car will stall would start right up but now will not start at all somedays no problems others would stall several times
Old 02-01-2005, 12:37 AM
wdking wdking is offline
Re: tach bounces stalls
I have the same problem, you'll notice as well if you put your computer readout to engine then battery that the voltage will jump around dramatically as well as the tach.....does your check engine light come on at all?
Old 02-08-2005, 02:46 AM
Engine light does not come on. I have changed alternator, fuel filter, fuel pressure regulator, and battery. Problem happens less often, but still happens. Is it the wires and plugs, is it the computer? Please give any information. Cannot find the book either. Thanks for responding.
Old 02-08-2005, 11:47 AM
kayaman420 kayaman420 is offline
Probably wires or plugs. Replace those first. ANd I cant stress enough to only use AC Delco replacement plugs and wires on these cars. You are begging for problems with aftermarket wires and plugs for theses Northstar engines. They are extremely touchy with there spark and the forums are littered with people who have had horrible results putting aftermarkets on these cars. Including myself.
After that I would try the coil pack. Maybe buy 1 new one and switch it around to see if it resolves the probhlem if it persists after the plug replacement.
Aurora 4.0---Anything less would be uncivilized!
http://members.cardomain.com/kayaman420
Old 02-13-2005, 04:41 PM
The Rebel The Rebel is offline
Re: Re: tach bounces stalls
computer...
Old 02-13-2005, 05:07 PM
Isnibs's Avatar
Isnibs Isnibs is offline
D.I.C...?
I have heard of other Aurora's with this problem
Turned out it was a bad ground connection.
http://www.automotiveforums.com/vbul...ghlight=ground
1996 Aurora Black / grey
Old 02-13-2005, 07:04 PM
Originally Posted by Isnibs
D.I.C...?
No Not the Dic(drivers information center).
