Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-24-2005, 12:26 AM
Brock_44 Brock_44 is offline
turbo acting up
my gsx is acting up. iv'e had the car for about a month now and it isnt running quite the same like when i shift and accelerate the turbo's boost goes way up and the car takes awhile to get going it's like the turbo is lagging. Is this a sign of my turbo going out or could it possibly be something else.by the way its the stock turbo and the car has 95,000 miles on it and everythings stock cept intake and catback exhaust.
Old 01-24-2005, 01:26 AM
joemathews's Avatar
joemathews joemathews is offline
Re: turbo acting up
You have boost leaks. If you had an aftermarket boost gauge, you would see that the boost is in fact not going up...
1996 Eagle Talon
Old 01-24-2005, 10:11 AM
Re: turbo acting up
what can you do too fix this?
Old 01-24-2005, 10:17 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: turbo acting up
you can leak test your car www.vfaq.com its like fixing a flat on your bike when you're 9. find the leak and fix it.
DSM geek
Old 01-24-2005, 01:55 PM
joemathews's Avatar
Re: turbo acting up
Specifically, http://www.vfaq.com/mods/ICtester.html
1996 Eagle Talon
Old 01-24-2005, 05:40 PM
Re: turbo acting up
another thing that it does is when starting the car the idle always bounces between 500 and 1000 rpms and sometimes it even drops down almost killing the car
Old 01-24-2005, 05:47 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: turbo acting up
fix the boost leaks first. sometimes they can cause weird idle problems depending ion how bad they are.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
