Old 01-23-2005, 11:25 PM
The Buzzard The Buzzard is offline
Swapped out cluster Now getting Code 17 VSS?
I have a 91 hatchback and just switched out the gauge cluster with one from a 91 crx si. Everything works fine until i back off the gas in any gear and the check engine light comes on. The ecu shows code 17. I have checked the speedo cable in the tranny and speedo its self. Switched the old one back in and it works fine. Anyone have any ideas, I am new to the whole honda thing.
Old 01-24-2005, 12:38 AM
88CiViC_D-15's Avatar
88CiViC_D-15 88CiViC_D-15 is offline
Send a message via AIM to 88CiViC_D-15 Send a message via MSN to 88CiViC_D-15
Re: Swapped out cluster Now getting Code 17 VSS?
there could be something wrong inside of the cluter you cant see, like a short or one of the wire things scraped or cut.
Team Lonely Drivers IS LOOKING FOR MORE MEMBERS,CLICK HERE
TLD FOURMS
- 88 civic std w/ sohc zc swap
- 88 integra ls, stock
- lookin for a 4dr. runnin or not
Old 01-24-2005, 12:43 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
code 17 is the speed sencer, im gunna say its hooked up wrong, or something with the swap doesnt agree with the meshing, my 98 s 10 is the same way if i try to switch my cluster for another one, even if its the s 10 blazer, or another s 10 i belve
Old 01-25-2005, 08:29 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
its definitely the cluster. either the cable isnt seating all the way into your cluster, or the components in the cluster that read the revolutions of the cable are damaged.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
