Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-23-2005, 09:47 PM
bigwally9876's Avatar
bigwally9876 bigwally9876 is offline
Send a message via Yahoo to bigwally9876
Angry distributor keeps burning out? help !!! pls.
ok one night i came home after driving my car ( it was running fine) went out the next morning to go to work and it would not start, it wasnt throwing any spark so i changed the distributor and then started fine, but i didnt drive it that day, went out today in it and put 17 miles on it came to a friends house and did a complete tune up , after the tune up started it up and was letting it idle when it shut off!!!! now its the same damn deal no damn spark some one please help!!!!!!!!!
Old 01-23-2005, 09:53 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: distributor keeps burning out? help !!! pls.
What year, model, engine, transmission etc are you talking about?
Normally, you don't replace the distributor as the first try at repairing a car that won't start. Why did you?
Old 01-23-2005, 10:05 PM
i got a 95 camry v4 i replaced it cause it wasnt throwing any spark as soon as i changed it i cranked right up but i need to know whats frying my distributors
Old 01-23-2005, 10:13 PM
Brian R.'s Avatar
Resident Chemist
OK, so you replaced the distributor and it still doesn't start. What makes you think it was the distributor in the first place? Did you test the input voltage to see if the distributor was getting spark before you replaced it?
Sounds to me like it's possible you didn't fix the problem in the first place rather than having a repeat of a problem you fixed.
Try testing the rest of the ignition system. Convince yourself there are no other faulty components. Ignitors are difficult to troubleshoot.
Old 01-26-2005, 09:40 AM
jsinton jsinton is offline
brian R. is right: Usually it is the igniter that goes bad. And they can do wierd things like you describe. Don't assume it's the distributor.
Old 01-26-2005, 11:45 AM
ok so if it was my igniter thats bad would that cause the distribtor to not throw any spark? and how come when i changed the distribtor the car turned on,(but then later died and then wasnt throwing spark again)
Old 01-26-2005, 11:55 AM
Brian R.'s Avatar
Resident Chemist
Igniter problems are commonly intermittent. Installing the new distributor may have caused the ignitor to work temporarily for some reason. This is all empirical. If it solves the problem, don't try and understand it.
A bad igniter would keep the entire high-voltage side of the ignition system from working - and not necessarily every day all day. It is like a bad coil, there is no easy way to predict it.
I'm not saying the igniter is bad, but it is more likely (and cheaper) than the distributor twice. Go with the probabilities. (if you have another car to install your old or new distributors in, you can figure out if they're bad or not).
Old 01-26-2005, 01:45 PM
It's entirely possible for the igniter to be the problem, they can have intermittant failure.
Old 01-30-2005, 11:53 PM
where can i find the igniter
Old 01-31-2005, 01:01 AM
Brian R.'s Avatar
Resident Chemist
Driver's side of the engine compartment behind the air cleaner box, bolted on to the fender. Usually they say "Igniter" on them
Old 02-14-2005, 04:35 PM
went to a junk yard to and got another ignitor but can any one think of an other reason why it may be having this problem
Old 02-17-2005, 12:10 AM
ok guys i really need help with this i have changed the ignitor and nothing same damn shit!
please help some one!
Old 02-17-2005, 08:35 AM
Brian R.'s Avatar
Resident Chemist
What have you done to test the ignition besides replacing the ignitor and distributor? When it runs, do you see a "Check Engine" Light? Does it ever run or is it dead?
Old 02-17-2005, 11:15 PM
oh its dead it try's to turn on but never makes it the only time it turned on was when i changed the distributor, no light
Old 02-18-2005, 07:26 AM
Brian R.'s Avatar
Resident Chemist
What have you done to test the ignition?
