Old 01-23-2005, 09:45 PM
bob_axum78 bob_axum78 is offline
Send a message via AIM to bob_axum78 Send a message via Yahoo to bob_axum78
Question 2 1989 Camaro Rs Swaping motors
I am going to switch the motor from one 89 to another wandering how hard this would be to switch and what the procedure would be to do so
Old 01-23-2005, 09:47 PM
panchoman's Avatar
panchoman panchoman is offline
Send a message via AIM to panchoman Send a message via MSN to panchoman Send a message via Yahoo to panchoman
Re: 2 1989 Camaro Rs Swaping motors
i asked a similar question not too long ago maybe it will help you here is the link http://www.automotiveforums.com/vbul...d.php?t=352356
"Hasta la victoria siempre!"-Ernesto "Che" Guevara
Old 01-23-2005, 09:53 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
just swapping the block? or the complete engine?(fuel/ignition,etc etc.) What engines are they?
If they are the same engines (89RS come with a 305tbi or a 2.8mpfi) Its just a matter of pulling one, and putting another one in its place..use colored tape to mark EVERYTHING (wires, hoses, etc. etc.) so you know where they go back.. if you've never done it before, take lots of pictures, it helps..
After you've marked it all, start unhooking everything and getting it out of the way.. (you'l probably need to take your hood off) take out the engine, and put the new one in and hook everything back up.. its pretty simple once you get in there..
BTW, its a good idea to change a few things on the good engine while you have it out.. such as, the rear main seal, oil pan gasket, things like that..
have I missed anything?
1991 Camaro Z28
Old 01-23-2005, 11:12 PM
Re: Re: 2 1989 Camaro Rs Swaping motors
It is a v6 going into a car that had a v6 in it only difference is the body which is t-tops to regular coupe
Old 01-24-2005, 12:15 AM
DaMoNe6969's Avatar
Just changin blocks? or are you swapping the complete engine?
1991 Camaro Z28
Old 01-24-2005, 04:53 AM
complete engine tranny everything mechanical
