Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 01-23-2005, 09:01 PM
B C B C is offline
water temp
When I tow at 4000 lb trailer with my E150 my water temp increases from the bottom of the 'M' in NORMAL to mid- 'A'. Is this normal ? It has a new radiator (<1yr). What should I look at.
Thanks
Bill
Old 01-23-2005, 09:47 PM
yotermanic yotermanic is offline
Sounds okay to me, when you're towing you're bound to build up a little extra engine temp, I wouldn't worry.
Old 01-23-2005, 10:37 PM
ModMech's Avatar
ModMech ModMech is offline
Re: water temp
Is your vehicle equipped with a towing package rated for that load?
If not, a better radiator and fan clutch, along with an extra ATF cooler is REQUIRED.
Old 01-25-2005, 10:43 PM
B C B C is offline
It has the tow package and the load is about 1/2 the rating.
Speaking of Trans temp. I want to add a Trans temp gauge. Where should I install it?
Thanks
Bill
Old 01-26-2005, 08:32 AM
caffie2 caffie2 is offline
Re: water temp
have a 1994 ford conversion van low heat output i have had it flushed, new heater core, thermostat,heatcontrolled valve,fan clutch,card board in front of radiater, heater hoses in & out get hot under car but not inside,
Old 01-26-2005, 11:27 AM
ModMech's Avatar
Re: water temp
Trans temp sender should be in the pan. MAX temp you want to see is 180*F for ATF if you want it to live a long happy life.
Caffie2,
The van you have does not, as I recall even have a water control valve, it uses a "blend door" to mix hot and cold to the desired result. The problem could be either the cable is broken or bent, or that the door seals are badly deteriorated, and you are simply getting too much cold air leaking thru it.
