Old 01-23-2005, 08:21 PM
poordudewhowantcar poordudewhowantcar is offline
Send a message via ICQ to poordudewhowantcar Send a message via AIM to poordudewhowantcar Send a message via Yahoo to poordudewhowantcar
zc vs. D 15 All Help Needed
Ok i was wondering if i should go through all the problems of fixing my d15 mpfi or sould i just get a new harness and drop a zc in my 90 dx?
Q. how difficult is it to do the swap on a budget ?
Q. who can help with the wiring harness.?
also this is a problem on my tranny: to put it reverse i have to slightly rev and drop the clutch/shift to R and it gives a slight grind. when i pop it out of R its the same as putting it in R. when i put it in 1st it nromal again (with the massive high rpm slippage due to the messed up clutch) .
Also where is the best place to buy in the Dallas metroplex area ?
What are the best starter mods to first put in a zc ? this also includes oil/filters any thing to get it up and running??
Old 01-23-2005, 08:35 PM
SiZ's Avatar
SiZ SiZ is offline
Re: zc vs. D 15 All Help Needed
The amount of money you would spend on a few bolt-ons to get your DPFI 1.5 up to maybe even 100 flywheel HP, you could have just bought a ZC..
Old 01-23-2005, 08:36 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
zc = hard to find parts for. You should get a d16a6
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 01-23-2005, 08:47 PM
well where can i get a vtec 1.6 at ?
Old 01-23-2005, 08:48 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
Re: Re: zc vs. D 15 All Help Needed
d16z6...almost same hp and tq of the dohc zc but you can find parts for it
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 01-23-2005, 09:14 PM
icE_x's Avatar
yeah d16z6 is pretty nice..i'd love to do a swap with that engine and bolt it up to my 4-speed - or get another 4-speed with overdrive...that'd rock!
Old 01-23-2005, 09:24 PM
im currently online searching for good prices on vtec d16's ill keep you posted on the results
Old 01-23-2005, 09:55 PM
90civicracer's Avatar
90civicracer 90civicracer is offline
Send a message via AIM to 90civicracer
d16z6 (92-95 Civic)
d16y8 (96-00 Civic)
Both SOHC vtec engins, 1.6 liters.
***90 Civic EX 4 Door***
Ace$nyper: yea it did woo woo 4500 posts i should be ashamed *kills self*
90civicracer: haha you killed yourself you got
Ace$nyper: OMFG LOL that might be the funniest thing you EVER posted
bwhahahaha
Old 01-24-2005, 10:09 AM
fast2camciv's Avatar
fast2camciv fast2camciv is offline
yea but if your on a budget a z6 or y8 is more expensive, you need a conversion harness for obd1 (assuming your obd0) and you need an ecu like p28 wich are hard to find and spendy. and the whole myth about zc parts are hard to find. totally untrue. there is not one part on a zc that you cant get. shit the block is identical to any other d-series. and they make cams and cam gears and intake manifolds for them too so im not sure what parts are the mystery parts. of all the people around that have zc's theres bound to be parts for them. i say go with the sohc or dohc zc or a a6. all will bolt in and be very cheap and easy.
Old 12-03-2005, 08:19 PM
x_outlaw_x x_outlaw_x is offline
Send a message via AIM to x_outlaw_x
used to have the same problem with the tranny...go into 1st before you go to reverse should fix it
