Old 01-23-2005, 08:05 PM
White Lightening's Avatar
White Lightening White Lightening is offline
What grade of GAS does a 2004 Silverado "Best" use ???
Greetings,
I have the 2004 V8 Vortec 6000 High Output gas engine (345 hp) known as the LQ9 (same engine as what comes in the Chevy SS and the Escalade). My compression ratio is 10 or more and reviews all say this engine uses Premium gas (while the normal 6 liter is a 9.2 compression and uses regular). But then I've been told by some friends that anything will work as long as it doesn't give you "knock".
Also - my engine is listed as a "flex fuel". With 3600 miles on it - I've used only Premium to this point. I fully understand the difference in quality of gas - I use only quality gas. That isn't what I'm asking. Most stations I go to in this locale are:
87 octane regular unleaded
89 or 90 octane unleaded with ethanol
91 or 92 octane premium unleaded
What should I use for my LQ9 ?
Also - what would you suggest for the 2004 5.3s and 4.8s?
White Lightening
Old 01-23-2005, 10:54 PM
Ape0r Ape0r is offline
Send a message via AIM to Ape0r
Re: What grade of GAS does a 2004 Silverado "Best" use ???
My '04 5.3 has never had anything but 87 in 17k miles. I've heard that using a higher octane. than required by the engine can cause carbon build ups.
With the higher compression ratio, you will need a higher rating. Maybe you should try a tank of mid-grade. To be safe, run it near empty, then dump 1/4 to 1/2 a tank of mid-grade, and see how it runs. If you hear it knocking, fill it up with the high octane stuff, and the knocking oughta disappear as soon as you get it thoroughly mixed with the gas already in your tank.
'04 Silverado 1500 4x4 5.3L 3.73 G80
Old 01-24-2005, 08:00 AM
Nigel215's Avatar
Nigel215 Nigel215 is offline
I use 89...just for a cleaner run and a little more pep. I havent heard any knocking.
2000 Silverado LS 4.8, K&N FIPK, Gibson Extreme Dual Exhaust, Line-X Bedliner, Black Speed Grille, Viper Alarm System, Custom Audio system.... (need to update my pic)
Old 01-24-2005, 09:00 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
I ran regular when I first bought my truck, then 2 months later, switched to 93 octane and have run that since. I have to now though becaue of my tune.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 01-24-2005, 08:54 PM
mrcrabbiepattie mrcrabbiepattie is offline
don't want to sound like a jacka.. but did you read your owners manual??
Old 01-24-2005, 09:49 PM
chevytrucks92's Avatar
chevytrucks92 chevytrucks92 is offline
My truck has never had nothing but 93 octane (92 K1500, 350, 130,000 miles). I know people say (and no doubt somebody will say in this thread) that if use higher then what the manual calls for, you're wasting your time.
Well, I dont believe that. You always get better gas mileage on higher octane then you do on lower octane IF you don't change your driving habits.
**1966 Chevy II**
355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4
Last Race (10-6-07) So its been awhile...
Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph
Fastest Pass of '07 (10-6-07)
60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph
25 and in BIG TIME Debt Crew member #2
Deuce's Wild Racing: Take a Ride on the WILD SIDE
Old 01-25-2005, 06:07 PM
Re: Re: What grade of GAS does a 2004 Silverado
Well, I'll be that somebody!
The octane rating has nothing to do with the quality of the gas. Nothing.
The octane rating is a rating of the fuels RESISTENCE to combustion. That is, the higher the octane number, the HARDER it is to ignite the fuel.
The reason that more expensive/sportier cars tend to demand higher octane fuel is because they (at least the ones that require it) use engines with higher compression ratios. If you put in fuel with too low of an octane rating, it will combust before the piston has reached top-dead-center, thus causing knock. However, if you put in fuel with an octane rating that is higher than required - there is no benefit. I have heard, and will not attempt to back this up, that using higher octane rated fuel than required can even cause carbon build-up due to the fact that the fuel simply won't burn as easily.
One would think that a fuel that burns easier will give you more power, not vice versa!
Now one must realize that any forum post is just opinion without something to back it up - here is mine:
"Some people believe that adding a higher octane fuel to their engine will increase its performance or lessen its fuel consumption. This is false - engines perform best when using fuel with the octane rating they were designed for."
http://en.wikipedia.org/wiki/Gasoline#Octane_rating
First link that came up on Google.
Old 01-25-2005, 07:40 PM
busta's Avatar
busta busta is offline
wow
i agree with ape0r , very well put.
-i love paintball
-i love datsun z cars
-oh i love my HARLEY!
-class A mechanic
-heavy eqipment mechanic
-equipment operator
-mig,tig,arc welder
-lemon silverado owner
-pistonslap.com
Old 01-25-2005, 09:45 PM
VTISC007 VTISC007 is offline
I also heard that, if your engine does not have the ability to properly burn higher octane fuel, the unburned fuel gets spit out of the tail pipe in the form of bad emissions. I live in California, and we have strict emission regulations. I agree, you should only use fuel with the octane rating that the manufacturer recommends. Imagine a piece of crap car with a four bangger. Do you really think that it will run better with mid grade or premium? I don't think so. If you run premium in the aformentioned vehicle, it will increase the amount of pollutants released into the enviornment because that engine does not have the compression rating high enough to burn high octane.
I know we are not talking about little 4 banggers, but that's just an example of how an engine without the compression cannot burn higher octane fuel.
Old 01-25-2005, 10:16 PM
RMW RMW is offline
Send a message via AIM to RMW
The Cheapest The Better 205,000 93 4.3still Going Strong But I Don't Pull Trailer And The 6.0 Also Gets The Cheapest Do Tow Trailer No Problems Yet
Old 01-25-2005, 11:58 PM
Re: Re: Re: What grade of GAS does a 2004 Silverado
Well, all I know is my truck gets anywhere from 18.3-19.6 mpg using 93 octane. My dad's truck (exactly like mine) gets 15.8-16.4 using 87. The only difference in his and mine is his has a locking differential (G80) and is a 91 model instead of a 92. His also has less miles (115,xxx to 130,xxx). That truck was bought used, and the only reason it gets 87 instead of a 93 is because that's what the first owner always used.
No body else's 350 TBI in a single cab, 4WD truck, 88-95 will get the same gas mileage that mine gets (by no body, I mean people that I actually know with similar vehicles).
Now that's a real life example. Maybe my truck is 1 out of a 100 that will do better on 93 octane, I dont know. I just know that it does, and in 130,000 miles, I have never heard a ping or knock yet (knock on wood).
**1966 Chevy II**
Old 01-26-2005, 06:49 AM
jeverett's Avatar
LOL, all this fuss over gas. I'm gunna say I'm one that actually has HUGE power increases from 93 octane. I can't even imagine me putting 87 in my truck now. Talk about knock!!!
All said, if I had never put a tune/chip in my truck, I'd still be running 87 octane.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 04-04-2006, 10:19 AM
silverado122775's Avatar
silverado122775 silverado122775 is offline
That says nothing.. considering I get 18.5-19.9mpg using 87 octane. I agree with everybody regarding the buying the higher octane fuel..It is a waste of money unless your vehicle requires it.
Having said that.. I am very strict on what brand of gas I use.. I tend to use Citgo the most because they are relatively cheaper than BP and Mobil and I have not had any problems using them. Now when I am on my long trips, Citgo's stations are not as popular as you would think. So I will settle for BP, Texaco, and even Mobil. Sometime's I will do the occasion Exxon, but only as a last resort. I never go to ma and pa gas stops.. you never know what they put in there gas.. in fact a lot of them put additives in them so that the gas burns faster requring more fill ups.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 04-04-2006, 04:23 PM
onehate02 onehate02 is offline
Send a message via AIM to onehate02
hey guys, i got an 04 ecsb, how big is my tank? i want to calculate my exact gas mileage. thanks.
2004 Silverado ext. cab 4.3L
Pirelli Scorpian A/T 275's
Magnaflow straight-through muffler (dumped)
K&N FIPK
Custom sound system (alpine/infinity/monster)
Billet Grille inserts & bowtie
Xenon blue bulbs (high/low/drl)
Limo Tint all around
Gaylords X-2000 tonneau
Rhino bed liner
Code Alarm keyless entry system
Custom PA system (dual speakers)
A1 Power Window mod
Center console swap
Old 04-04-2006, 04:32 PM
you have a 26 gal tank.
Short Box 6' = 26 Gal
Long Box 8' = 32 Gal
