Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 01-23-2005, 07:20 PM
chembrad chembrad is offline
Uh oh... this is bad
Only a couple days ago I put my Jimmy back together. It's a 1994 V6 Vortec (W) auto everything with 113300 miles.
After replacing the heater core, water pump, thermostat, coolant hoses, vacuum hoses, upper intake manifold gasket, CPI unit, nut kit (inj. lines), lower intake manifold gasket and both rocker arm cover gaskets...
I also flushed the heck out of the coolant system and put in fresh coolant.
Now the coolant is all brown. In less than one tank of gas!!!
This is a bad thing I'm thinking.
Yes there is also some water vapor coming out of the tailpipe.
Is there any good way to figure out which head is leaking?
Or should I just go ahead and replace both head gaskets?
The good news is that since I just did everything down to the lower intake, that far is going to be easy the second time around...
When I get the head off, anything I should check while I am at it?
'05 Dodge Grand Caravan 105k miles
'94 Geo Metro 1.0L 5spd 185k miles... at least I can fix it!
Old 01-23-2005, 07:30 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Uh oh... this is bad
Check you oil level?
Also, did you replace the rad cap?
What coolant did you use to refil the system?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-23-2005, 07:56 PM
Re: Re: Uh oh... this is bad
Yes. Doesn't seem to be too much lower. Only about 1/2 L
Yes. Brand new.
Prestone new yellow. Diluted 2:1 for 66% conc.
The engine runs pretty nice, so that is why I think it is only 1 cylinder or so that is leaking.
Old 01-23-2005, 08:00 PM
And where can I get a good gasket set for this engine?
Old 01-23-2005, 08:05 PM
BlazerLT's Avatar
AF -Advisor
From the dealer really.
But it sounds like you have a head gasket gone.
Old 01-23-2005, 10:47 PM
Yep. That is what I think too.
I found this place on-line for gasket sets:
http://www.hi-performance.com/rolgasketsets.htm
But I have a '94 262 V6 (W) [although I don't know the diff between the W and Z vin]
So I'm going to call them and see if they have a gasket kit for my engine.
Old 01-24-2005, 12:03 AM
BlazerLT's Avatar
AF -Advisor
Wouldn't it be smart to find out the problem BEFORE you buy parts?
Old 01-24-2005, 07:28 AM
Well, I'm getting oil in my coolant and coolant in my engine. So I'm pretty sure it is the head gasket.
Is there any way to tell for sure without taking the engine apart?
It is not leaking outside that I can see. Only internally.
Old 01-24-2005, 07:54 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Yep, blown gasket... Personally I like Felpro's much better than OEM..(just my opinion)
I hope you didn't hurt the bearings..
Old 01-24-2005, 11:29 AM
Also I saw a Victor Reinz tech bulletin on the 4.3L head gaskets up to '95. VR makes a layered gasket that I'm going to try. I don't want to have to do it again... Carquest sells the VR gasket kit (excluding the exhaust flange manifold gaskets) for ~US$70.
So now I am back to my other question: When I have the head off, what do I need to check for wear and what should I be looking for? How do I check the bearings to see if there is damage?
Old 01-24-2005, 11:32 AM
rlith's Avatar
To check the bearings you need to pull the oil pan. As to when you have the heads/lower intake off, clean the egr ports and make sure that ALL gasket material is removed.. Cover the oil valley with news paper, then use 75-100 grit sand after you've used a razor blade. Clean with alchohol.
Old 01-24-2005, 03:19 PM
BlazerLT's Avatar
AF -Advisor
Oh, there is coolant in the oil?
Old 01-24-2005, 04:12 PM
My bad. Correction: oil is in the coolant, and coolant (or water) seems to be getting into the combustion chamber. Although I am not sure about this one because I do not have anything to compare it to. But I have water dripping out of the tail pipe and white vapor as well even after it has achieved normal operating temp.
The oil doesn't seem to have any coolant in it (afaik). I just am losing oil volume into the coolant.
Old 01-24-2005, 04:17 PM
Doesn't this require lifting the engine from the vehicle?
You mean on the lower intake mating surface. I just did the lower intake and I only used a sharp putty knife followed by green scrub pad and an exacto knife.
I didn't want any grit in my engine.
Old 01-24-2005, 04:55 PM
BlazerLT's Avatar
AF -Advisor
If you do NOT drive it while it is like this, you should be fine and you will not be required to inspect the bearings.
Seeing you are stating there is no coolant in the oil, you are safe.
I would replace both head gaskets but don't disregard that it might be that intake gasket you installed.
Did you install it to the proper torque spec?
