Old 01-23-2005, 07:14 PM
mofo313 mofo313 is offline
1997 stalls when idling
Anyone have/heard of this problem in a 1997 4cyl automatic? It stalls out (and is very difficult to restart) whenever I'm stuck in prolonged stop-go traffic. Thanks for your help!
Old 01-23-2005, 10:18 PM
noshun's Avatar
noshun noshun is offline
Re: 1997 stalls when idling
Is this at normal temp or does it get hot. Does your car seem to be losing power at all?
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
Old 01-24-2005, 09:38 AM
running warm
This is usually after it's been driven for a while and always happens initially in stop-go traffic. After the first time it happens there is typically a loss of power as well as "hiccups" when accelerating.
Old 01-24-2005, 10:32 AM
noshun's Avatar
Re: running warm
Could be an ignition problem. How old are your spark plugs and wires? They may be the problem. Does it stall when you are stationary or when you go to move off? It could be a tranny issue but I doubt it! Also, how old is you fuel filter? This could also be the pronblem if not a contributing factor.
Old 01-24-2005, 11:02 AM
It usually stalls when idling, and I don't know if I mentioned this but it only seems to happen during warmer (60+) weather. Thanks for all your help!
Old 01-24-2005, 05:07 PM
noshun's Avatar
Re: Re: 1997 stalls when idling
I'd say fuel line then! Run some injector cleaner and the highest octane fuel you can get.
Old 01-24-2005, 05:16 PM
Do you recommend any certain type of injector cleaner? Thanks for your help!
Old 01-24-2005, 05:39 PM
noshun's Avatar
Just any from a reputable company like STP or similar. They're all pretty much the same. You can even shop by price if you want! I'm not sure how good the NOS on is but STP would probably be better anyway. I use STP or Pennzoil. If you buy a multipack you can do it for say 3 consecutive tankfuls and after the first you could probably go back to regular gas!
Old 01-31-2005, 12:06 PM
Thanks for your help, we're back up and runnin again!!
Old 02-01-2005, 09:35 AM
kamakasi kamakasi is offline
Send a message via AIM to kamakasi
ding ding ding unhook torque converter front of tranny run good as new look 1/2 mile per gallon
Old 02-01-2005, 10:12 AM
noshun's Avatar
I think you mane the Torque Converter Clutch and if you disconnect this and It isn't the problem as shown it isn't you lose gas mileage on the highway!
