Old 01-23-2005, 06:56 PM
turbo ES turbo ES is offline
305 or 350
is it worth modifying a 305TPI or should i just go for a 350 and bolt my fuel injetion on with bigger injectors but id rather have a fast 305 just to be a lil diff seems like everybody talks about how 305s are trash but i think you could make a 305 pretty quick with not so much money anyone and my car has an emissions blower on the exhaust to pass emissions or somthn will it run right with out it?
Old 01-23-2005, 07:00 PM
MMonnier2302 MMonnier2302 is offline
stock most 305's are boat anchors. However it and all GM engines have lots of potential. Change the cam, but some good heads on, carb or injected you'll have a quick car.
i love dem bats!!
1995 Camaro Z-28
2000 Dodge Ram 4x4 Sport 5.9
Old 01-23-2005, 07:02 PM
Re: 305 or 350
what heads would you suggest
Old 01-23-2005, 07:04 PM
Re: 305 or 350
you think it would take a supercharger very well? i think it has like 9:1 compression or higher doesnt it id like to keep it pretty streetable
Old 01-23-2005, 07:05 PM
Vortec are great, check edelbrock. But any high flowing heads should do fine.
i love dem bats!!
1995 Camaro Z-28
Old 01-23-2005, 07:06 PM
supercharger would be ok. but you'd want the cam first.
i love dem bats!!
1995 Camaro Z-28
Old 01-23-2005, 08:30 PM
CORE402's Avatar
CORE402 CORE402 is offline
Re: 305 or 350
Really the 305 is not much of a motor. It has a hard time fighting off detonation, even with aluminum heads. With its tiny bore it keeps the valve size very limited. If you have the money get the 350. If you are on a tight budget then stick with the 305.
1973 Camaro
AFR 195cc heads
CNC Motorsports 383 short block
Comp Cams hyd flat tappet
TH350
Dual 3" exhaust (LOUD)
Corporate 10 bolt w/ all new internals and axles
Old 01-23-2005, 08:33 PM
CORE402's Avatar
Re: 305 or 350
if it comes down to a blower you'll want the less aggressive cam. If you put an aggressive naturally aspirated cam into a supercharged motor you'll over scavenge the exhaust and actually lose power as opposed to if you just left the stock cam in..
1973 Camaro
AFR 195cc heads
TH350
