Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 01-23-2005, 06:03 PM
97 silverbullet's Avatar
97 silverbullet 97 silverbullet is offline
Send a message via AIM to 97 silverbullet Send a message via Yahoo to 97 silverbullet
problems
ok I keep on getting this passkey system fault, and well its causing alot of problems, my speedometer keeps jumping around, so does the tach, the tranny drops into a lower gear then speeds up to get into the higher gear whether in any driving mode such as cruise on a flat road for hundreds of miles, then the speedometer stops working and looks like im going 140 and the temp gauge stops working. There is def a electrical problem, and also the car doesn't start, doesn't turn over, just sits ther like the clean key wait 3 min thing pops up, but I believe its the nuetral safety switch but I dont know since all these other problems are happening, i relplaced the starter, battery ignition switch. Pain in the butt and Im sick of it. can anyone help.
[On his running for California Governor]
It's the most important decision I've had to make since 1978 when I decided to get a bikini wax.
-- Arnold Schwarzenegger
Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 01-23-2005, 09:14 PM
treeboy38's Avatar
treeboy38 treeboy38 is offline
Re: problems
Sounds like it is probably a grounding issue somewhere. Try and find out the factory grounding points and tighten them.
1997 Burgandy Aurora
