Go Back   Automotive Forums Car Chat > Fabrication & Tools > Metal Shaping and Welding
Metal Shaping and Welding Discuss metal shaping and welding techniques. Share your projects or tips and tricks.
Old 01-23-2005, 05:32 PM
info2x info2x is offline
Send a message via AIM to info2x Send a message via Yahoo to info2x
Exclamation Welding concern
This coming summer I'm going to be doing a lot of work on my car, before it gets any worse. This means welding is a must, but here is my problem. What about the gasoline in the gas tank, should I take it out because running high current through the car doesn't make me feel all that safe. Also what about the car electronics will those need any prepping before I strike the first arc? I don't think the rest of the car needs to be prepped, except the weld area obviously.
- INFO2X
1985 Volvo 240DL Wagon
Silver Bullet Restoration
Old 01-23-2005, 07:24 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Welding concern
Hmmm. I've never welded on a car with electronics and a gas tank in place, except for a few exhaust systems. To be on the safe side you could take out the electronics.
Definately take out the gas tank, and purge the lines.
-Mike
Old 01-23-2005, 07:39 PM
Crud... That's what I was afraid of.
- INFO2X
Old 01-24-2005, 02:54 AM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
Re: Welding concern
I don't really think there will be a problem with the gas tank, I've never seen a spark anywhere besides where you're welding. I have heard that you should definately unhook any computers, as welding will most likely fry them. I don't think its as much of an issue on older cars without computers, but things like guages might go screwy.
Old 01-24-2005, 10:27 AM
Ok it seems that removing the gas although not required is an added safety and the battery should be disconnected. What about the grounding wire for the car electronics, should I remove that or would that cause more problems?
- INFO2X
Old 01-24-2005, 11:27 AM
duplox's Avatar
Re: Welding concern
I'd just unplug the car's computers entirely. Leave the wires alone, they won't be hurt. Unplug the CD player/radio, windshield wiper delay box, and efi/timing computers. And of course the battery, I can't believe I forgot that...
Old 01-25-2005, 05:28 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: Welding concern
and any other electronics just disconect the ground. current cant come from the + power cable as the battery is disconected.
Old 01-26-2005, 11:44 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Welding concern
current wont ignite the gas, to unless your tank is leaking, you should be fine, as for electronics.. just unplug your battery.
Old 01-26-2005, 03:36 PM
You're right it shouldn't ignite the gas, but I just wanted to hear it from other people as well.
Next time I go home (Feb 18th) I'll be looking in the shop manuals for my car for any discrepancies with what was posted here.
- INFO2X
Old 01-26-2005, 06:20 PM
Kind of a Big Deal
Re: Welding concern
well think about it, if current ignites gas... then the slightest defect in the wire insulation in you electric sending unit or fuel pump would ignite it, i think automotive companies wouldnt want that kind of liability in MOST of there cars.. and as for the electrical... if there is no juice goin through your wires.. how can it fry anything? just make sure you ground the welder to a spot close to where youre welding and youll be all set.
Old 01-29-2005, 11:14 AM
What about the wire going from the engine block to the body? Should that be removed?
- INFO2X
Old 01-29-2005, 12:58 PM
duplox's Avatar
Re: Welding concern
The grounding strap? I can't imagine that will have any negative effects.
Old 01-30-2005, 08:59 AM
CBFryman's Avatar
Banned
Re: Welding concern
Actually now that i think about it. it would be safer to have a full tank of gas rather than a tank full of perfectly mixed with oxygen gas fumes...
Old 01-30-2005, 09:35 PM
Oh so that's what the grounding strap is.
As for the gas, you make a very good point.
- INFO2X
