Old 01-23-2005, 05:10 PM
Razul Razul is offline
Send a message via AIM to Razul
1990 Cavy Battery problem
My Battery has not been getting a charge it will hold a charge but if the engine is runing the battery will die after running for an hour or two. The alternater is new i just put it in.
Old 01-23-2005, 10:23 PM
noshun's Avatar
noshun noshun is offline
Re: 1990 Cavy Battery problem
Check the connections on your alternator. They may need cleaning or may even be lose!
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
Old 01-27-2005, 09:18 AM
the connections are fine i have checked them plenty of times
Old 02-04-2005, 06:11 PM
Greenman8 Greenman8 is offline
Your new alternator may be bad... I got a bad one this last year and took forever to diagnose it.
Mr. Green
Old 02-16-2005, 08:11 PM
noshun's Avatar
Re: Got the problem fixed
I got the problem fix. I brought it to my machanic and it was the wires coming of the alternater were corroded so that was what was causing the problem.
I'd hate to say I told you so! So I wont!
Old 02-16-2005, 08:37 PM
The problem was the wires coming of the alternater were carroded. not that the alternater was bad itself.
Old 02-16-2005, 08:42 PM
noshun's Avatar
Re: Re: 1990 Cavy Battery problem
that was my 1st post the cleaning would get rid of the corrosion. Using some sandpaper you could have gotten the metal shiny and the contact would have been good and it would have worked!
Old 02-17-2005, 07:15 AM
not the connections the wire between the alternater and battery was bad. it was not letting the power travel across.
