Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 01-23-2005, 05:10 PM
MYSONOMA MYSONOMA is offline
1998 Surges
MY 1998 4.3 sonoma surges on acceleration and loss of power when going up hills, when cruise is set it also surges, when I give it to much gas rpm increase but will not shift or pick up speed. had 3 codes cat system efficiency below threshold(bank 1), mass or volume circuit range performance problem, and intake air temp circuit high input. replaced plugs , cap, rotor, pvc, air filter, mass air flow sensor, also done a visual on air intake duct. also engine light was on. cleared codes, ran for several days no new codes but still runs same. anyone have any ideas that I can check out before I go and spend to much money at the shop. (please help). (truck has 103,000 miles, mostly interstate miles)
oh, I also replaced fuel filter 100 miles ago.
Old 02-01-2005, 02:09 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 1998 Surges
Have the codes checked again.
Not all codes set a check engine light.
Was the O2 code for bank 1 sensor 1?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-05-2005, 04:36 PM
Re: Re: 1998 Surges
THANKS FOR REPLY, SAME CODE CAME UP AGAIN CAT SYSTEM, SO I TOOK A CHANCE AND TOOK EXHAUST APART AND FOUND CAT WAS HALF PLUGED, CLEANED OUT AND RUNS GREAT.
