Old 01-23-2005, 02:50 PM
cordovaass's Avatar
cordovaass cordovaass is offline
Send a message via AIM to cordovaass
hypertech TBI power charger
does any one out there have a hypertech TBI power charger on their truck? if so would you say it was worth it?.. im looking into it because it says 10 horses at the rear wheels for like $43.
Old 01-23-2005, 11:29 PM
KarpoSVT KarpoSVT is offline
I got one a couple of weeks ago. I put it on 3 days after putting on my Thorley Headers, and also the same day I put on a MSD Coil & Wires. So it was hard to tell just what the PC added. I read in Car Craft an article where they put it on a 93(I think), dynoed it and got a true 8hp.
Also I cut the bottom of the air cleaner to the same size as the PC, only makes sence. The theory is that our TBI acually suck air in from the sides because of the injectors being right over the throtle holes, so if you widen the spacer (PC is same width at base but like 1"-2" wider at top) you get more air flow which = more HP.
The power increase according to the dyno chart that came with it, adds midrange HP not off the line power. So your not going to notice much if you want that seat of the pants feel. I would recommend it though, anything that can help these motor breathe more/better is a good thing. Hope this helps,
karpo
"Have You Pulled A Ford Lately"
1995 GMC Z71 5.7L
Removed Air Silencer
Hypertech Power Charger(Cut bottom of Air Cleaner,took out Thermovac)
Injector Pod Spacer
MSD Coil
MSD Super Conductor Wires
Flex-a-Lite Flex Fan
180' Stat
Thorley Tri-Y Headers
High Flow Cat
Cat Back Duals w/glasspack 2 1/4"
