I just recently bought a 95 continental and love it! It was great the first few weeks but then I noticed the fuel economy started to go down. But I had just realized that it took premium fuel where as I had been using regular. When I switch to premium is when the fuel economy went down. So I switch back to regular and the fuel economy stayed bad. Then the engine started to run rough and finally the check engine light came on. I scanned it and it said it was a misfire on cylinder four. I replace the spark plug and measured the resistance on the cables, which seem fine. I check the coil resistance but am not sure I did it right. Any advice on how to check the coil or any ideas on what else might be the problem? Thanks all.
Check some of these Tech Articles to see which apply to your Lincoln.
Chances are you may have to deal with several issues.
-Steven 1996 Town Car, Cartier |
Re: 95 continental running rough/misfire
I have the same year same model same problem with number 2 cylinder. I was told it could be a stuck fuel injector. I haven't had a chance to try and fix mine yet. I hope that's all it takes because after the plug, the wire, and the injector is the camshaft.
