Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 01-23-2005, 01:56 PM
jeep crawler jeep crawler is offline
Transmission help
I have a 99 Grand Cherokee Laredo V-8 4.7 automatic 4X4 Quadra Trac II. My transmission won't shift correctly. My check engine light came on so I took it to a transmission guy. He said the codes said it wasn't shifting correctly into certain gears. It seems to skip 2nd gear and won't go into overdrive on the freeway. The fluid is in great shape, no additives. It seems to be electrical. He checked the relays, they seemed fine. The TCM has writing on it like it was recalled for reprograming. Could that be the problem? Also, my battery terminals have been coroding alot this past year. Could it have surged? Any advise is helpful, please!
Old 01-23-2005, 07:05 PM
mx52nv's Avatar
mx52nv mx52nv is offline
Re: Transmission help
hmmm, sounds like a sensor
current rides:
1990 Turbo Miata
lifted and locked 96 Grand Cherokee with other toys under the hood
retired rides:
1996 Eclipse GSX
1991 Stealth
1991 Porsche 993 C2
1988 BMW 520i
Your SUV isn't a Jeep, and my Jeep isn't an SUV....
SCCA, where you actually learn to drive
Old 01-23-2005, 07:09 PM
xj31 xj31 is offline
if you could get the codes,that would help.
Old 01-24-2005, 10:37 AM
The codes just said that it wasn't shifting right. No information as to why. The mechanic said it is skipping 2nd gear and not going into overdrive. Inside the transmission seems to be fine, which leads us to believe it is something electrical.
Old 01-26-2005, 07:31 AM
there are specific codes.it doesn't just say the trans is not shifting right.if he can't give you the actual codes,you should find someone who can
Old 01-26-2005, 10:43 AM
Smile
The transmission shop recovered the specific codes. "not shifting into 2nd correctly, or missing it.", for example. Just for informational purpose in case anyone else has a similar problem: I took it to the dealer, they said it was an "input sensor". It assists in sensing electronically what gears it should be in. At $90 an hour, total with the part $188. So far she's running well!
