Old 01-23-2005, 01:18 PM
mapeebles1 mapeebles1 is offline
ignition switch
How do you change the ignition switch on a 1994 chevy blazer tahoe LT eddition? It is not in the chilton or other books they only made this truck one year and I can't find the anwsers anywhere please help!
Old 01-23-2005, 08:41 PM
tom3 tom3 is offline
Switch is on steering column under the dash. Remove lower dash cover, unbolt and lower steering column, unplug wire harness at switch and remove. Sounds easy, but not much access to it. Try this site for better info maybe:
http://www.sourcenet.ca:9001/servlets/Home
Old 01-25-2005, 06:01 PM
Re: ignition switch
thank you I got it but now the truck still wont start Could it be the lock & Key it seams as if it is not turning all the way I took the starter to checker auto parts they tested it and it is fine what else could it be?
Old 01-25-2005, 07:22 PM
oldmanneedshelp oldmanneedshelp is offline
Re: Re: ignition switch
PERHAPS SOLENOID
Old 01-26-2005, 01:31 AM
Re: ignition switch
I will check that tomorrow maybe I can get this truck running in a day or so. Thanks
