Old 01-23-2005, 12:38 PM
shadoww shadoww is offline
no power
97 cav 2.2 act's like the cat is cloged up ,half throttle is all she will do.
any thing over that the motor will stumble,it will not back fire...
i took off exhaust at manafold,made made no differance,also changed plugs,wires.coil packs.had the box the coil packs bolt to checked out at advance auto they said it was ok ,checked fuel pump pressure at tank 60 psi droped to 35 when power shut off,new fuel filter,replaced p.c.m no change.......one weird clue while engine is at idle,I can switch plug wires 2 and 3 runs the same I can also switch plug wires 1 and 4 no change in the way the motor runs while moving the throttle.also did compression test 180 in all cyl 's
Old 01-23-2005, 09:53 PM
noshun's Avatar
noshun noshun is offline
Re: no power
Does sound like the inerds of the cat have collapsed and are blocking the exhaust flow! I woudn't go swapping plug wires around by the way. That's really not good!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
Old 01-24-2005, 03:22 PM
z24 fanatic z24 fanatic is offline
Send a message via AIM to z24 fanatic
Re: no power
you might want to get your computer checked out and swapping wires can be bad
Old 01-24-2005, 05:37 PM
noshun's Avatar
Re: Re: no power
He replaced the PCM after he got the problem and no change.
Old 01-25-2005, 07:09 PM
godenm's Avatar
godenm godenm is offline
Re: Re: no power
i think he said he unhooked exhaust at manifold and didnt help.
Old 01-25-2005, 07:11 PM
godenm's Avatar
Re: no power
does it do it when engine is cold/hot,both??
