Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 01-23-2005, 12:11 PM
housejudge housejudge is offline
Question 97 jimmy, ignition problem
I started having this problem just after thanksgiving. when i turn the ignition over it sounds like its cranking, but wont start. I noticed that the dash lights(brakes, air bag, seat belt, etc..) are not on. When the lights are on, it starts right up. Sometime on right away, sometime wait two or more minutes. I was told that the ignition is bad, but I hear a clicking noise under the dash when the lights come on, is this a relay??
Anyone an Idea??
Old 01-23-2005, 02:20 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: 97 jimmy, ignition problem
The ignition switch is is the dash, it isn't the part that you put the key in. Your problem does sound like you need an ignition switch. I know for a fact that the 97 blazers are notorious for bad ignition switches, I'm not sure about the Jimmys though, but regardless, it does sound like you have a faulty ignition switch. You can do a search in the blazer forum and get tons of info.
Old 01-23-2005, 07:33 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Re: 97 jimmy, ignition problem
No, it is in the steering column.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-23-2005, 07:48 PM
blazee's Avatar
Problem?
Re: Re: Re: 97 jimmy, ignition problem
I just meant that it was internal and not the part on the outside that you put the key in.
Old 01-23-2005, 08:06 PM
BlazerLT's Avatar
AF -Advisor
Ah, you said it was in the dash.
Old 01-31-2005, 12:01 AM
nighthog nighthog is offline
I had this same problem and replaced the ignition switch. All works fine now. Before you get started replacing the switch get an E-4 torx socket. The book said it's installed with screws, but the screw had a e-torx head. I spent more time tracking it down than replacing the switch. It's not a hard job, just follow the book and take your time.
