Lowered Tundra
Hi guys,
ANY PROS/CONS on lowering tundra??What setup to use and brand to use??I have 05 tundra and wanting to lower it a bit maybe 1.5/3 thanks guys
Re: Lowered Tundra
go check out tundrasolutions.com - or specifically sosperf.com: they make a 1.5/3 kit for your truck. |
I just lowered my 2000 4-door with the SOS 1 1/2 front X 3 inch rear kit. Encountered three problems. First, I have the TRD Side-Exit dual exhaust. The tail pipes will not clear the rear springs. Second, the kit drops the rear more than the front. You will end up with a 1/2 in higher front than rear. Last, the truck will ride a lot rougher. The rear is lowered so much that it bottoms out on the overload spring with the slightest bump. This takes some getting used to since the truck rides so smoothly in stock height.
good luck- Quote:
