Old 01-23-2005, 10:59 AM
cavypower05 cavypower05 is offline
How to Lower 01 Z24?
Does anyone have any detailed instructions on how to lowering springs and shocks/struts?
Old 01-23-2005, 11:00 AM
install lowering springs and shocks/struts******
Old 01-23-2005, 01:30 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: How to Lower 01 Z24?
Teamforwardmotion.com use to have a step by step how to, but i just tried getting it for you and its no longer there.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 01-23-2005, 01:33 PM
Lifted GMT-360!
http://www.j-body.org/forums/read.ph...=77664&t=77664
Here is one where a JBO member shows how to do a KONI yellow and Eibach pro kit install. Its the exact same just if you do not use koni, don't worry about all the steps on modifying the struts.. JUST READ IT ALL!
Old 01-23-2005, 09:50 PM
noshun's Avatar
noshun noshun is offline
put some jubilee clips around your springs a few coils apart and tighten them until the desired amount is taking out.
Seriously though never do this or anything like it!! Don't ever cut springs either it's not good!
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
Old 01-24-2005, 09:54 AM
z24 fanatic z24 fanatic is offline
Send a message via AIM to z24 fanatic
i was about to say the struts would blow if you did that
Old 01-24-2005, 10:34 AM
noshun's Avatar
Re: Re: How to Lower 01 Z24?
Not necessarily. If you get low enough, on to your bumps stops they wont come into play that much! It'll be like having NO suspension though!
Old 01-24-2005, 10:36 AM
Lifted GMT-360!
^^ remember you need to cut the bumps stops when lowering though ... in between the first and second bump...
Old 01-24-2005, 10:46 AM
thats true but thats on hell of a ride
Old 01-24-2005, 01:26 PM
nfg2184 nfg2184 is offline
I don't think I want to lower anymore. I bet my system would skip like nuts.
-2004 Cavalier LS
Mods:
Weapon-R Short Ram, Shift Kit, Nitrous Express Wet Kit, Upper/Lower mounts.
Audio:
15" RE .SE sub to BRUTUS 1500, 6.5" RE components in the rear, Apline's in front, all to Pheonix Gold Profile, Alpine deck.
-1997 Sentra XE, 5-speed POS, commuter.
Old 01-24-2005, 02:52 PM
Lifted GMT-360!
Even after you properly cut the bump stop where its suppose to be done, the only way you will hit it is if your cutting coils out of your springs. Coilovers are only designed to go to 3" below factory level and even then you will not touch it. You would have to be a stupid ass to even try to be this low. The ideal drop on J-bodys is 1.4" to where the A-arm is parellel with the ground. Anything more than its considered an agressive drop. It puts more stress on the CV shaft.
You should ask someone that owns lowered a car and did the drop themselves oversome who just relays messages that they have read and has no idea on what the ride feels like. I have ridden in an 00 sunfire with Goldline springs (1.7 F, 2.3 R) and KYB GR-2 struts. This ride was really good and the tires were always planted on the road and the bumps were a bit hard but his alpine deck never skipped once. Currently i have dropzone(1.7 F, 2.3 R) on factory struts. The ride is extremly bouncy because i don't have revavled struts to compensate for the higher spring rate. Note the fact i hate the bounce, my deck has only skipped once and it was when i hit a rather large pot hole and blew my crappy stock tire. If you do a good setup spring wise and strut combination you will be surprised on how much better your car will feel and handle. I already have my new setup for the spring whick will be Eibach Prokit(1.4") with KYB GR-2's. This setup so far has run me $550 bucks.
Old 01-24-2005, 03:38 PM
if i got another lowerning kit i would get tin (i think thats how its spelled) lowering springs with the air balance ajuster to smooth out the ride i rode in a 03? dodge srt4 with that and the ride was so smooth you could set a wine glass on the back bench with out it spilling and that was a 2.0 inch drop
Old 01-24-2005, 05:22 PM
noshun's Avatar
You means TEIN. they're $1300 though for the full coilovers!
My sony deck only skipped once. But that was after I got air off of a railroad crossing!!!! I wont do that again though! I hit my head on the roof where I came out of the seat and though that my car probably didn't like it either.
Old 01-29-2005, 09:50 AM
would a camber kit be necessary?
Old 01-29-2005, 10:13 AM
Lifted GMT-360!
^^^ No... but you do need an alignment ASAP.
