95.5 Rodeo 4X4 Rear Suspension (leaf springs)
Has anyone replaced the rear leaf springs. Mine seem to be very weak. I bottom out now on bumps that wouldn't have done it earlier. If so where did you get them. Are they OEM or aftermarket. Thanks
Brian |
Re: 95.5 Rodeo 4X4 Rear Suspension (leaf springs)
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
You might want to check your rubber shackle bushings before you drop a bundle on springs. I had the bottoming noise on my 93 Rodeo and traced it to metal to metal at the rear shackle. If your springs are toast, take them to a spring shop for a re-arch.
GEG |
In regards to the statement above, I too have been expereincing this annoying issue (new rear shock though). Has anyone changed the rubber shackle from the leaf spring setup? Is this easy to swap out? My leaf springs are still ok though.
_________________ T O N U P B O Y "That which does not become a part of the one, shall become one with the void." Allegiance: None Function: Universal Dominator ![]() 2001 Nissan Pathfinder 1993 Isuzu Rodeo 4WD V6 |
I have a 1994 Isuzu Rodeo (2.6L 2 wheel drive) and have experienced the very same issues you have described. I would bet you anything that the leaf springs on the rear end of your Rodeo are just weak form time and travel. The easiest way to address this issue is by installing a set of leaf spring helpers. They are often used to stiffen the rear suspension for carrying the extra weight when towing, but the also will help add new life to worn/tired leaf springs. You can find them sold in pairs ranging in price from $39.99 + from several internet based stores and at local stores such as Advanced, Autozone, Pep Boys, etc. I installed a set of leaf spring helpers on my Rodeo in less than a hour and it made a world of difference, no more bottoming out or leaning heavy in a turn.
This thread is 6 yrs old, I bet he solved his problem by now
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs 80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ... 89 4Runner - stock 2000 Isuzu Trooper + 2010 Sonata |
Probably so. I just wanted to share what I experienced for anyone else that may stumble across this old thread like I did while researching the same types of issues.
