Old 01-23-2005, 08:13 AM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Will any Computer case work?
Will any computer case work with any motherboard? I have an ASUS P5A-A Super Socket 7, so what cases would work with that?
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 01-23-2005, 08:41 AM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Re: Will any Computer case work?
The older super socket 7 boards aren't that big and should readily fit in probably most of the current available cases in just about any store.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 01-23-2005, 09:00 AM
Shaguar47's Avatar
Is there any way to tell if it will fit for sure in the case? Do they tell you what fits cause I can't find on any case descriptions what fits.
Old 01-23-2005, 04:10 PM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
Most mobo's will fit in most cases. The only way to know for sure is to try it - buy a case from somewhere that does returns or exchanges.
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 01-24-2005, 01:43 AM
Ultimate X's Avatar
Ultimate X Ultimate X is offline
Send a message via AIM to Ultimate X Send a message via MSN to Ultimate X
it should fit in most cases unless u wanna replace the mobo in a retail pc
2004 Toyota Solara V6SLE
3.3-liter DOHC
24-valve VVT-i V6
225 hp @ 5,600 rpm
240 lb.-ft. @ 3,600 rpm
Old 01-24-2005, 02:47 PM
I would also recommend you buy an ATX compatible case. Your super 7 board is most likely ATX, but it might be AT as well. You may want to look into that first before making a case decision. Most ATX cases can hold an AT board though.
Old 01-24-2005, 05:45 PM
Phieta Phieta is offline
Send a message via AIM to Phieta Send a message via MSN to Phieta Send a message via Yahoo to Phieta
I know the P5A Super 7 is ATX, and the P5A-A should only be slightly different, so yours is most likely to be ATX as well.
