V8 Conversion Front Coil Springs Needed
1988 S-10 Blazer
Looking to find replacement front coil springs other than OEM HD's [4.3L w/AC] adding aprox 200lbs to front not intrested in air/spacers, ect, somebody has already done this, what replacement coil used based on coil dimensions, not/ incl free standing height. donot want to lower/raise vehicle oem height. So far i have one source working with them midwest spring co. Iowa. 1 [800] 424-0244, they purchased Landrum Spring Co. Only mgr Auto/Truck coils. still waiting for answer from them. Looking for other solutions/sources. Hopefully somebody can help out\Thanks Otherwise, project is comming along fine, Frame Off Restro, Frame Expoxy Primered, Shot w/Truck Bed Liner Spray and all related parts, poloy bushing entire, firewall ECM Mod's completed, moved ECM, Ect to Drivers Side Under Brake Booster Area. Rear-End Bolt 1999 Yukon SUV 8.6 Cut-Down, Eaton 35 Spline w/ mosier axels, People oare out of Jackson, NJ. Get some coils, body goes back on, start setting engine. JLDrescher [email protected] Thanks Again
Jeff Drescher
Re: V8 Conversion Front Coil Springs Needed
Try this site http://www.cheaptruckparts.com/subcat.asp?338
Re: Re: V8 Conversion Front Coil Springs Needed
somebody i'am sure has already replaced OEM with another vehicle coil that works for this application/situation. Did like the rear air bagsat site, will be re-installing trailer hitch, so rear sag willl need air bag assist when loaded, thanks. Still looking.
Jeff Drescher
I'm getting a custom made bumper for my blazer that has a class 3 hitch built right in for less than the hitch would cost me alone.
I do have welder friends, one whom is doing the job, but it should be reasonable for everyone to get made up. It's only some round pipes, and some box steel |
Jeff Drescher
Re: Re: Re: V8 Conversion Front Coil Springs Needed
You should really be able to get any local welder to do it. If your stuck I'll see what I can do though |
Hi Jeff If you want I'll be on line tonight, around 11 west coast time, and my chat line in MSN is
[email protected] or in Yahoo. siu681 People are sleeping in this house then, so I shouldn't really talk on the phone then. I might even be on line as early as 10, when I can have my mic hooked up Later then |
