Old 01-22-2005, 10:05 PM
88CiViC_D-15's Avatar
88CiViC_D-15 88CiViC_D-15 is offline
Send a message via AIM to 88CiViC_D-15 Send a message via MSN to 88CiViC_D-15
d15 turbo 1
ok, im sure this has been asked a thousand times, but what turbo would be best for a stock d15b2 with stronger rods and a sohc zc cam for a homemade turbo. also i need to know how to run the vacume lines and also some info for a fuel management system, how it works and do i need it to push 150 to 200 whp. also, can i diable the internal wastegate or take it off the turbo to use a external or is a internal as good as a external and how do i set my psi without a turbo timer or do i need a turbo timer. i only want to run like 7 to 9 psi for now till i build another engine. please i would like some help with this. Thanx
Team Lonely Drivers IS LOOKING FOR MORE MEMBERS,CLICK HERE
TLD FOURMS
- 88 civic std w/ sohc zc swap
- 88 integra ls, stock
- lookin for a 4dr. runnin or not
Old 01-22-2005, 10:17 PM
5gcivic's Avatar
5gcivic 5gcivic is offline
Re: d15 turbo 1
Look at my post in the classifieds for a t3 turbo. About the rods you really dont need to go buy new fancy forged rods, have your stock rods to a machine shop and have them shot peened and resized. That will strengthen your rods well enough to run the boost levels you are talking about. I was running 10.5 psi on stock shot peened rods on a d series motor. You will have to get some turbo pistons with lower compression. I got JE forged pistons just for saftey and to make some more power. For fuel management you should get an FPR, larger fuel pump or an extra one, FMU or a SAFC or both. A turbo timer does not set boost, it keeps your car running after you take out the key so the turbo has time to cool off. You can get a manual boost controller($100) or an electronic boost controller($200-500). On my d16z6 I was making 187 with my set up using the stock cam.
Old 01-23-2005, 10:59 PM
Re: d15 turbo 1
but what is the differnce between the internal wastegate and the external wastegate?? and if its internal, can i take it out and just use a external?? also what size t3 turbo should i run and i need help with vacume lines if theres any to run from the BOV or the wastegate? Thanx guys and gals
TLD FOURMS
Old 01-23-2005, 11:03 PM
Re: d15 turbo 1
also what is a fmu and a safc?? dont know the terms yet about things. im still a newbie at imports. i know alot about chevys though, that was my thing for a long time till i relized that imports are alot cheaper than trying to get a chevy as fast as a honda
TLD FOURMS
Old 01-23-2005, 11:08 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: d15 turbo 1
did you do the mpfi swap or are you still dpfi
Team Lonely Drivers
Old 01-23-2005, 11:14 PM
pika pika is offline
Re: d15 turbo 1
geez bro how big r the wheels on ur civic like 19", those look mad ricer yo.. geez
Old 01-23-2005, 11:19 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
Re: d15 turbo 1
150 - 200 hp on a d15b2 with 7-9 psi..... aint gonna happen, if the turbo has an internal wastegate, just keep it, it can be adjusted, turbo timers do not set the boost, turbo timers keep the car idleing for a certain amount of time with the key out so that it can cool down properly and not cake the oil onto the turbo, u would need a boost gauge and adjust the wastegate untill u make enough boost. its better to get forged rods and new pistons too just to be safe
Old 01-23-2005, 11:20 PM
1PhatCX's Avatar
Re: Re: d15 turbo 1
dont come into threads flaming, its a great way to get banned
Old 01-23-2005, 11:24 PM
5gcivic's Avatar
Re: Re: d15 turbo 1
The internal wastegate is used on most stock turbo vehicles, I have never used an external wastegate just internal and have had no problems so far. Im sure you could remove it but that would require a new turbine(exhaust) housing and would just be a hassel. You should run a vacuum line from your intake manifold to your bov so when you let off the throttle the bov can open and let the boost escape. The wastegate will have a small hose connected to it goin to the turbo compressor housing. Look at some pics on the web, they are all over the place. Go to yahoo and type in internal and external wastegate and youll get tons of info on how they work and what the best one is to use on your application.
Old 01-23-2005, 11:28 PM
5gcivic's Avatar
Re: Re: d15 turbo 1
An FMU is a fuel management unit-it restricts fuel returning to the tank depending on boost level therefore increasing fuel pressure so you dont detonate or cause other serious damage to your motor. SAFC is an electronic fuel controller made by Apexi. Lets you play with your injector pulse width and some other stuff.
1PhatCX's Avatar
Re: Re: Re: d15 turbo 1
actually u dont need a new exhuast housing, i have a td04 that had an internal wastegate on it, they welded a small piece of metal over top to close it off. so now i have to use an external one
Old 01-23-2005, 11:59 PM
Re: d15 turbo 1
thanx for the info guys, no im still at dpfi but soon to upgrade to a mpfi, just wanted some info so when i do turbo. i know that i have to get new and stronger internals. also my car has 16" rims, its just the way it was sitting when i took the pic, i have a lowering kit, just havnt had the time to put it on yet, been working lots of hours at work. how much does a fmu cost and a turbo timer, im trying to keep cheap for now with my budget. i want to turbo my d15b2 stock with like 5 to 6 psi if it posable for a while till i get my other engine built. but i do really adpreciate all of your input.
thanx again
TLD FOURMS
Old 01-24-2005, 12:02 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
if you still have the dpfi (dual point fuel injection, basically throttle body injected), you should look into converting it to mpfi (multi point juel injection). I mean you dont really have to but it will get you closer to your goal of 150-200hp. do a search for mpfi conversion to get more info on how to do it. But as you said, if your just doing this till you can build another engine keep it dirt cheap if you want. Or you could just suck it up and turn this into your built engine
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 01-24-2005, 12:04 AM
shit, you posted as i was typing
ZC stuff
Old 01-24-2005, 12:06 AM
Re: d15 turbo 1
i dont want to turbo with a dpfi, they are no good to me, i want a mpfi. i know alot about d15's but just not much about a turbo. i also wanted to know what size turbo would be good for me and what car can i get it out of at a scraping yard?
TLD FOURMS
