Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 01-22-2005, 10:00 PM
daviddh85 daviddh85 is offline
Help! Starting A Rotary Engine That Has Sat For A Year
I NEED HELP WITH MY 1981 RX7. JUST BOUGHT IT, HAS A 12A AND HASN'T BEEN RUN IN A YEAR. DOES ANYONE HAVE ANY KNOWLEDGE ON THE BEST WAY TO GET IT RUNNING AGAIN? NEED THE GET IT RUNNING TO GET IT TO THE RESTORATION SHOP I WORK AT TO START THE RESTORATION. THANKS. EMAIL ME AT [email protected] WITH YOUR HELP, OR JUST LEAVE A REPLY.
Old 01-22-2005, 11:58 PM
D3rELiC's Avatar
D3rELiC D3rELiC is offline
Re: Help! Starting A Rotary Engine That Has Sat For A Year
first, get some high octane engine starter, poor some MMO (marvel mystery oil) in the rotor chamber by the sparkplug holes and turn the crank, do this to get some oil in every rotor chamber, it will prevent carbon lock and over heat when you'll try to start the engine after a day or two of crank turning once in a while.
make sure the cats arnt cloged, if they still exist, lol
Old 02-05-2005, 09:09 AM
ghostrx7's Avatar
ghostrx7 ghostrx7 is offline
Send a message via AIM to ghostrx7 Send a message via Yahoo to ghostrx7
try disconnecting the engine inj fuse and cranking it for a good 10-20 secs.then replace the fuse and try again.it works on my sec gen when it doesnt start.goodluck
88 10th anniversary rx7 and company h2.
[IMG][/IMG] [IMG]
atkins streetported 3mm seal engine, act clutch, lightweight flywheel, downpipe, straightpipe, greddy power extreme exhaust, hks ssqv blow off valve, short shifter, tein flex suspension, energy bushings, bonez intake, new brakes, rotors, toyo tires, mazdaspeed replica seats
Old 02-05-2005, 11:54 AM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
he didnt say it was flooded.
RX-7 TII
Old 02-08-2005, 12:50 PM
J-Rat's Avatar
J-Rat J-Rat is offline
Send a message via AIM to J-Rat Send a message via MSN to J-Rat
Re: Re: Help! Starting A Rotary Engine That Has Sat For A Year
A small problem with that suggestion..
The 81 FB was carb'd, so it would not have an engine INJ fuse..
Just a little "gee whiz" info for ya.
1988 10th AE Edition TII
More mods then you have.
Old 02-08-2005, 01:10 PM
MBTN's Avatar
MBTN MBTN is offline
Send a message via AIM to MBTN
New battery (doesn't have to be NEW, but a nice strong one is good.)
Get rid of that old gas in there.
A little MMO in the rotor chambers, crank it a bit. Then new plugs. Finally, pray!
Old 02-17-2005, 06:30 PM
Thanks everyone
Got it running, smoked like crazy for about 10 minutes but is idling well and oil pressure is right where it should be. Now, the restoration will begin.
