Old 01-22-2005, 10:33 PM
NRDaddy NRDaddy is offline
Car Installation Help!
Man... I'm lost.
So this is everything that happened. I got my CDX-M8805X today and went ahead and installed it. Worked up the harness and got it in and everything. It worked for about 2 minutes and when I got back to my car from cleaning up, the face was off and I couldn't turn it back on. But the motorized face was still working and the cd eject was still working.
So after a lot of thought, I figured it was the ignition on wire. I fed power to the deck with the continuous power wire and it all worked. But now my clock doesn't work. I had to think about that too, and now I think that there's a possibility that my whole ignition power wires have failed.
I'm not sure since I don't know much about it, so I'm hoping someone else might. As of right now, the only two things that don't work is the clock and the A/C on light.
Any ideas?
Old 01-23-2005, 01:05 AM
RickwithaTbird's Avatar
RickwithaTbird RickwithaTbird is offline
Send a message via AIM to RickwithaTbird Send a message via MSN to RickwithaTbird Send a message via Yahoo to RickwithaTbird
Re: Car Installation Help!
fuses?
R.I.P.: My Thunderbird "Ricks 96".. 2/08/96 - 1/14/05.
Old 01-23-2005, 10:47 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
you blew a fuse.
Old 03-05-2005, 06:34 PM
gfrank17704@people gfrank17704@people is offline
how to remove radio from 97 park avenue
Old 03-06-2005, 04:34 AM
low low is offline
Send a message via ICQ to low Send a message via AIM to low Send a message via MSN to low Send a message via Yahoo to low
are you sure you connected the right wires?
ok I don't want to assume that you do or do not know much about installing a head unit. if you don't then it sounds to me like you may have hooked up your wires incorectly. now if you did hook this up correctly then I beleve that your question has already been answered (its probably a blown fuse that is causing you to not get a constant power so your clock and radio presets will only have power when the ignition is turned on) if this doesn't help you can message me on ICQ, Yahoo, AIM, or MSN just click on the icon on this post. you could even email me @ [email protected] and we could walk through the process together and figure out what the problem is.
