Old 01-22-2005, 07:31 PM
sLADe781 sLADe781 is offline
Removing Oil Filter Tips
Okay guys, I just got raped trying to take off my sisters stupid oil filter. It's so damn fuckin' tight that it won't budge...AT ALL!!!! You guys have any tips that could possibly help me get it off? And yes, I was using a stinkin' oil filter wrench but still, nothing.....
Old 01-22-2005, 08:27 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
you said that you were using an oil filter removal tool???
is it really cold in your area...you may want to try warming the car up just a tad. when you get it off and you put the new one, always dip your finger in oil and rub it around the seal of the oil filter. this keeps it from getting stuck...
good luck!!!
i am having the same problem with a spark plug...its in there damn good and i dont want to put too much force on it becasue i dont feel like removing my heads to get the broken plug out. that would suck...
ZedEx Crew Member #4
Old 01-22-2005, 08:29 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: Removing Oil Filter Tips
Yeah, umm there's oil filter pliers that work pretty good, pick up a pair of those.
If that's not an option take a flat head screwdriver and a hammer, and hammer at the base of the filter in the direction you want it to turn (always works).
Also if you happen to have a big adjustable wrench or a monkey wrench that you can tighten down on the filter and turn it with, that might work.
Last resort, hammer a big screwdriver straight through the filter and use it as lever to turn it. But not straight through the center, you don't want to damage the threads you screw the filter onto.
Old 01-22-2005, 08:31 PM
Also when you do get it off and put the new one on...turn it until the seal first touches the base and then turn it ONLY another 3/4 of a turn. Then it won't get stuck...most filters say to do that on them, but just in case you didn't know.
Old 01-22-2005, 08:42 PM
I can't turn the car on because I already drained the oil. Also, if anyone else has any other tips please keep 'em coming. I can't work on it anymore tonight because it's too dark but I will be out there tomorrow so yeah.... I don't want to spend the whole day doing it beause I have other things to do. But yeah, I will try the suggestions. I'm feelin' so hopeless right now....ugh!!! Thanks for the help guys.
Old 01-22-2005, 08:51 PM
Oh yeah, one more thing.....you know when we're down there facing the oil filter? We're supposed to turn it COUNTER-CLOCKWISE right? I know, stupid question but I remember I was turning it the wrong way one time and didn't realize it. :o/
Old 01-22-2005, 11:27 PM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
take a look at the threading on the filter you bought, the new one you will be putting on after you get this one off. by looking at the threading you can determine which way to turn. if you filter removal tool didnt work its probably because its floating and the filter is too small, just use a rag wraped around the filter to make it a little wider, then the removal wrench will be able to get a better grip on it. try to find some rubber or leather gloves too, get good grip with those. if nothing works take a long ass screw driver and drive it through the bottom across and twist and yell out BOOYAAH!
06 GTO: SLP Longtubes, SLP Loudmouth II K&N intake,
Ported Intake Manifold,
Ported Throttle body, MAF screen delete.
Tunned by Jeremy Formato. 381whp, 376wtq.
07 Ion Redline: Bone stock w/ factory Competition package.
In response to a race my wife had while pregnant with our baby:
Originally Posted by jeepgclwj
Prediction.... I bet we will hear about a guy down in Miami thats the King of street racing in about 18 years...Way to get him started....
Old 01-22-2005, 11:37 PM
Hehe Thanks Musashi! When....IF...I get it off, I'll be sure to yell a loud for ya. Then I'll get up and chuck the stupid filter accross the parking lot into the fire lane wall. Thing is though, I tried that one sticking the screw driver through the filter before and didn't turn. That's why I didn't try again today.... :o/ Any thoughts?
Old 01-23-2005, 12:19 AM
Z Cars Fanatic
Re: Re: Removing Oil Filter Tips
do you have a torch???
wow...if you stuck a screw driver through that thing and it still didnt budge. its really on there. that screwdriver trick is usually a sure fire thing. i would still try heating it up a little bit...if you dont have a torch maybe a heating pad might help or soemthing like that.
Old 01-23-2005, 12:04 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Just count your blessings that your not shoveling and blowing out of 3 feet of snow.... that keeps getting blown back into place by the gale force winds.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 01-23-2005, 05:22 PM
Okay guys, here's what happened today.... I got up at 7 in the morning and went back under my sister's car. After trying for another 30-45 minutes, I decided to call it quits. Who cares if I would have to pay money for a stupid oil change....I just wasn't gonna deal with it anymore. So I packed up, put the old oil back in the car, came back into the apartment broken, and moaped around as I waited for the oil changing place to open. After about 3 hours of waiting and calling around, my dad calls to see how everything was going. I told him that I couldn't do it and that I would just go and get it done at a shop somewhere. Instead of saying "yeah, okay go" (which is what I thought he'd say), he replied with "GO back down there and keep turning. It'll move...eventually." LOL Shocked and somewhat inspired, I went to lunch and headed back down there yet again. So there I was trying to remove the stupid filter but still, NOTHING. The oil changing place wasn't open today and since my sister needed the car by tomorrow, I relented and decided to go to Walmart to have it done (I didn't want to go to Walmart because they changed my friend's oil once and did something wrong so her engine fried). Well, when I turned on the car and looked under....yep, you guessed it....oil was dripping from the filter. Don't know if it was busted or if I moved it, but I knew I wasn't gonna make it to the shop. So yeah, I went back down (oh my gosh, that routine have gotten so redundant by this time), heaved and shoved and pushed and pulled and finally, it budged. So there you have it....the moving of a oil filter that broke me more times than once...
I can't believe how hard it was to remove her filter. It's kinda always like that with her Eclipse...you guys have any ideas why? It's just her car. Mine, my mom, my dad's, everyone elses comes off except hers...UGH!!!! Just glad it's over with....
Oh yeah, Musashi, after the filter came off, I gave a nice "BOOYAH" salute and chucked it across the parking lot into the fire lane wall. Hehe
Old 01-23-2005, 07:17 PM
HELL YEAH! I am so freaking proud of you man!
you can get a real nice set of filter pliers for $7.00 at autozone. I'll take a pic of mine and post it tomorrow.
Old 01-23-2005, 09:15 PM
Do those pliers really work? My buddy was telling me how he uses a water heater plier but it's because he has a truck lifted high up. I have those filter caps that goes right under the filter but they didn't fit the old filter I had on. But yeah, I probably will need to invest in one of those pliers if they really work.
Old 01-23-2005, 10:20 PM
Z Cars Fanatic
i think it came loose becaue it warmed up a little bit and got a little warmer oil moving over the filter, making everything expand and loosen. i hate to say it, but i told you so... j/k!!!
im glad it came off for you...did you remember to put the oil around the little rubber seal befroe you put the new one on??? that will keep the rubber from getting stuck on the block...hence your stuck oil filter.
Old 01-23-2005, 11:03 PM
Yeah k3smostwanted, I put oil around the little rubber seal area before screwing it on. I'm sure it was done last time too but I think my dad just overtightened it because he was mad. But yeah, do you really think the filter came lose because it was warmed up? It seems kinda weird that that would be needed because after I moved my car for a minute and went under, the exhaust piping was so hot that I couldn't even get to the filter (my arm kept touching it). And the Eclipse filter is right next to the exhaust piping too. :o/
