Old 01-22-2005, 06:41 PM
Grebus1 Grebus1 is offline
Interior lights stuck on w/door ajar light not on
The interior lights on my '97 are stuck on, but the door ajar light on the dash is not. It goes out after all the doors are shut, but the interior lights stay on. I've tried the WD-40 trick on the door latches, but it did not have any effect. Any ideas/suggestions?
Old 01-22-2005, 07:01 PM
yotermanic yotermanic is offline
You might make sure your dimmer switch isn't turned all the way up, this causes the dome lights to turn on and if it is not, you may see if the switch is bad. Many times if you don't have a door ajar light on, the dimmer switch on the headlamp switch is what causes the dome light to stay on.
Old 01-22-2005, 07:14 PM
Thanks, it didn't immediately occur to me to check that, but when I went out just now, the lights seemed to flicker when I manipulated the switch. I'll replace it and hopefully that will do it. Thanks again!
