Old 01-22-2005, 06:25 PM
zetaracer zetaracer is offline
Help me build my suspension.
I want to change out a lot of stuff on my factory DX suspension.
I want to know (performance wise) what I can change out without hurting my daily driveability too bad? I want a car great for straights, curves, and around town crusing.
What are some pros and cons of things like;
ITR lcas
sway bars
alignment kits
strut bars
urethane bushings
full adjustable coilovers
etc....
Any and all info will help.
I've searched the web and info comes up short or confusing.
Old 01-22-2005, 06:38 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
Re: Help me build my suspension.
well there arent really any cons of strut/sway bars they will keep your turns tighter and keep the body from sawying. the new bushings will jsut help the ride be alittle cleaner. as for the adjsutable coilovers well if your jsut gonna buy coils and put them o nyor ustock struts is not bad u jsut get alittle bit bouncer of a ride. but i would probably reccommend struts and coils packages if your going lower then 1.5 inchs.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 01-22-2005, 07:35 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
here's what i would go with
TEIN SS coilover suspension....................................$100 0
suspension techniques energy suspension kit...............$140
suspension techniques rear sway bar..........................$140
ebay rear lower tie bar............................................$10
ebay front lower tie bar..........................................$10
neuspeed strut tower bar.........................................$110
ebay/ skunk2 rear strut tower bar.............................$10/ $135
ingalls camber kit............................................... ..$122
total for a good suspension.................................$1542/ $1667
that's all i can think of right now...but if ur gonna do ur suspension, might as well do your brakes next
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 01-22-2005, 07:52 PM
Blu civic,
This would be safe for daily driving. I really don't want a shitty ride or tires being eaten monthly.
And brakes are next, I can push the brake pedal all the way to the floor with no give. I was thinking rear disc conversion of some sort and wilwood fronts.
But, right now I'm focused on suspenion and driveablility.
Old 01-22-2005, 08:13 PM
BLU CIVIC's Avatar
調整器
Originally Posted by zetaracer
Blu civic,
if u think this won't be safe or will cause u to go thru tires...then u should keep ur suspension stock and not ask at all
price is new from manufacture...can probably get this cheaper on ebay or at different web site...this is just what I would use...u can add or take away from some of the things i mentioned or go with a different manufacture
The name's Adrian
2011 CR-Z - Stock
Old 01-22-2005, 08:36 PM
I want a simple suspension- similar to a stock type-r in performance and driveability. But, I don't want to change out something if it causes problems in driveability now or in the future. I want pros and cons mainly on LCAs, radius rods, alignment kits, and urethane/rubber bushings.
Old 01-22-2005, 08:47 PM
BLU CIVIC's Avatar
調整器
there are no cons about the suspension setup the i showed u other than the price...and if u want something good for your car then it ain't gonna be cheap...nothing to change out, nothing to adjust (except the ride height and strut damper setting when u want to be more aggressive)
difference between urethane/rubber bushings is that urethane is better but if u don't lube it, it will squeek
by alignment kit u mean camber kit? everyone has their opnions on which set-up and manufacture to go with
other than that...i'm sure someone else can help u
The name's Adrian
2011 CR-Z - Stock
Old 01-22-2005, 09:04 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
search Tein on ebay for your car...and get polyurthane (sp?) bushings (master bushing kiy made by energy suspention $135)
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 01-22-2005, 09:08 PM
Price is not too much of an issue. What you listed can be obtained fairly easy.
I meant progress alignment kit.
Thanks for the info Blu.
Old 01-22-2005, 09:11 PM
what happend to jackassi? he was the suspention dude
1990 si hatch
b20b si tranny
50 shot
1994 Dx hatch
stock
Old 01-30-2005, 07:03 PM
Nybody have Omnipower coilovers? How are they?
Old 01-30-2005, 07:33 PM
CR50HC CR50HC is offline
I think you should fix your brake pedal problem first. Safety should be your first priority. After that do your suspension.
Old 01-30-2005, 08:44 PM
BLU CIVIC's Avatar
調整器
decided to do a write-up of my dream suspension...may come true if i get this full time job dedicated to my car
TEIN SS Coil-Over Damper Kit
MODEL # DSA36-KUSS1………………………………………………………………………….………$1000.00
Suspension Techniques Sway Bars (f & r)…………………………………………………… $339.57
Model # http://www.optionimports.com/52155s.html
Energy Suspension Kit…………………………………………………………………………$135.00
Model # http://cgi.ebay.com/ebaymotors/ws/eB...category=42609
Neuspeed front upper strut towers……………………………………………………………$103.59
Model #: 352070 http://www.performancepartswholesale...brand=neuspeed
Neuspeed rear lower tie bar……………………………………………………………………$77.68
Model # 452014 http://www.performancepartswholesale...brand=neuspeed
90-93 Integra front and rear disc brake conversion…………………………………………….
Axis Maglite (Graphite) rims……………………………………………………………….…$899.00
Model # Wheel & Tire Package 1-15x7 http://www.wheelmax.com/Wheels/Axis/axis.htm
Brembo Grand Turismo Brake System/ GT Junior ………………………………………….
Model # PT# 11.5002A….contact race technology 310-306-3158
Cusco front lower tie bar……………………………………………………………………….. $85.71
Model # http://www.optionimports.com/307-475-a-.html
Cusco rear upper strut tower………………………………………………………………….. $251.43
Model # http://www.optionimports.com/307-551-a-.html
Orijin Motorsports Solid Control Arm Bushings……………..……………………………….$95.00
Model # EFUCABN001 http://www.orijinmotorsports.com/prodefen.html
Ingalls Camber Kit (x2)…………………………………………………………………………$244.76
Model # 35720
So far $3231.74
The name's Adrian
2011 CR-Z - Stock
Old 01-30-2005, 09:00 PM
Well , I'm going to to order some coilovers first. Then, address my brake problem. After that I will work on completing my suspension. The car will be safe before my engine swap.
While we're on the subject of brakes
I know the wilwood big brake kit would be worth it, but I hear upgrading larger rotors hurts acceleration. Is this true?
Are there any aftermarket OE sized kits?
Blu,
I would try convert brakes to those of integras but, It is just easier for me to order from a website than search the junkyards.
And I also heard an aftermarket front sway bar creates too much understeer. Is this true?
Thanks
Old 01-31-2005, 08:26 AM
BLU CIVIC's Avatar
調整器
it does create a lot of understeer...but i think itz better to have both on the street rather than just one...and to take the front off when at the track...atleast i think that's how it goes
The name's Adrian
2011 CR-Z - Stock
