how do you install hood pins?
how do you insall hood pins i need to kno step by step
pick a spot on your hood, check to see if you can mount the actual bolt piece into something solid underneath, when you find a spot make sure you line up everything perfect, take a drill and drill a hole into your hood and into the frame. then install the pins.
1991 Honda Civic DX Sedan |
Re: how do you install hood pins?
a buddy of mine, TSC, says "easier to mount the studs, then put a glob of grease on them, shut your hood then drill where the middle of the grease mark is at"
then he said "or if you dont have greese, just slam the hood really hard and it will leave dents where you need to drill lol"
It's better to drill from the top side down so the edges of the hole don't ruin the finish on the top side. You'd also want to put some masking tape over the area where you're drilling so you don't scratch or crack the surface.
real question is...do u need them or did they just look good on the shelf at autozone
The name's Adrian 1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills 2006 G35 Coupe 6MT - Stock 2011 CR-Z - Stock |
Re: Re: how do you install hood pins?
_________________________________http://VelocityFactor.com________________________________ 1990 si hatch b20b si tranny megan race header 2.5 custom exhaust 50 shot integra da rear disk (w/ 4040 valve) powerslot rotors and barded lines all around 1994 Dx hatch stock |
hmm...guess i have been a lil hasrh...guess itz the kids and the cold buggin me
do what Siz did and use a plate to mount the pin, best idea so if u have to remove em u can and just weld the holes back up haha
94 s-10 bagged, body dropped, 22's, suicide coupe doors, fully shaved, and soon a small block 350 2011 Silverado... Stock Daily driver
No welding! They're plates that have holes in 3 spots where stock bolts go for your fenders and the top two on your headlight rails.
If I wanted to go away from pins, I'd have no holes drilled, and they're easier to work with if you ask me...
"The nympho of info, I'm fuckin' what ya heard"
no i ment if u get rid of the pins, u can weld up the hole in the hood.... but u have a cf so yea doesnt work haha
