Old 01-22-2005, 05:45 PM
Leoaviles Leoaviles is offline
heater problem
i think my blazer has a problem because whenever i turn my heater on for a while and then i turn it off i still feel heat in the car especially comming from under dash. any suggestions?
Old 01-22-2005, 06:09 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: heater problem
You are talking about when you turn off the fan?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-22-2005, 06:20 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: heater problem
Heat blowing or heat radiating?
If heat blowing:
Does it vary with vehicle speed?
If heat radiating:
Your heater core is under the dash, when you turn off the fan the fan stops circulating the hot air, but if you leave the temp control knob turned to heat, the hot water will still circulate through the heater core and radiate through the dash.
Old 01-22-2005, 06:24 PM
Re: heater problem
yes when i turn off the fan.
oh so its the hot water circulating huh ok i thought for some reason the heater would still be on.
thanks fort the helguys.
Old 01-22-2005, 06:32 PM
blazee's Avatar
Problem?
Re: heater problem
It may not just be the water circulating through the dash. Check to see if you can feel it blowing from under the dash with the fan off while driving. And if it varies with vehicle speed.
Old 01-23-2005, 05:32 PM
BlazerLT's Avatar
AF -Advisor
Re: heater problem
You will still have some warm air coming from the heater core even with the fan off.
Completely normal.
