Old 01-22-2005, 05:37 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Is this normal?
When i have my headlights on and the heater on full bore the battery voltage indicator drops to 10 and my lights get really dim inside and out. Is this bad wiring or just normal and i just noticed it ?
Old 01-22-2005, 06:05 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Is this normal?
No that's not normal, you need to check and clean your connections at the battery and alternator. It could mean your alternator is taking a shit.
Old 01-22-2005, 06:07 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Is this normal?
Yip, alternator is weak.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-22-2005, 07:29 PM
molehole's Avatar
molehole molehole is offline
Send a message via AIM to molehole
Re: Is this normal?
Yeah sounds like a weak alternator to me also. Make sure your connections are tight and not corroded. How old is your battery? My Blazer does it also sometimes but the alternator is pretty new and so is the battery. Sometimes with a bunch of stuff on the voltage can drop.
Good Luck
Old 01-22-2005, 07:35 PM
Re: Is this normal?
i dont know how old the battery is
prob really old cuz it came w the rig ill check it out
Old 01-23-2005, 05:40 PM
BlazerLT's Avatar
AF -Advisor
Re: Is this normal?
I would focus more on the alternator.
Old 01-23-2005, 06:14 PM
Re: Is this normal?
thats not good at all im gonna clean the battery out tomm
Old 01-23-2005, 06:32 PM
BlazerLT's Avatar
AF -Advisor
Re: Is this normal?
Maybe you should charge it as well.
Old 01-23-2005, 07:12 PM
Re: Is this normal?
ok i might as well get er checked at autozone i got to fix the 4wheel drive first so i can get there
Old 01-29-2005, 06:47 AM
Re: Is this normal?
sorry about the late response i had my dad jump it and it did not it and the connections are not corroded so i am leaning towards the alternator. It has gotten somewhat worse but not to the point of extreme. Are there any tips that i should use when taking one out and does the belt need to be slackened or will it just slide out when it is unbolted.
Old 01-29-2005, 07:09 AM
blazee's Avatar
Problem?
Re: Is this normal?
Make damn sure your battery is fully charged BEFORE you connect the new one or you will take years off of it's life span.
Old 01-29-2005, 08:52 AM
Re: Is this normal?
ok i will throw it on the charger before i do it thanks for the heads up
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 01-29-2005, 09:14 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Re: Re: Is this normal?
You need to remove the belt before removing the alternator, and disconnect the battery before removing the connector on the alternator.
Get yourself a 1/2" drive breaker bar to release the belt tension (Insert the drive in the tensioner pulley, it has a square drive opening in the center of it).
Old 01-29-2005, 09:22 AM
talonx talonx is offline
Re: Re: Re: Is this normal?
I just put a new alternator in my 99' blazer last week. Just the
belt and a few bolts. Make sure you disconnect the battery first.
