Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 01-22-2005, 05:04 PM
staruser staruser is offline
Send a message via Yahoo to staruser
Question over heating problems
i have a 86 rx 7 gxl and whenever i start to turn it over it some how gets pressure into the cooling system if it even dont start. and when i start it up than i shut it down than all the coolant pushes into the overflow and doesnt suck back in, whats wrong? well i took me intake manifold off and checked the gaskets, because i was thinking maybe the exhaust manifold was blowing hot air into the cooling system to make it overheat within 2 minutes of it starting up, it it is warmed up or not, i dont have a clue. but i noticed the intake manifold gasket had sand in between the gasket and the manifold and it was built up all over the place from the previous owner, and i also took the radiator hoses and checked them out and there was that same sand in it. could it be that gasket and exhaust that gets into the system?
Old 01-22-2005, 05:24 PM
89tracerman's Avatar
89tracerman 89tracerman is offline
Re: over heating problems
i think you have a blown coolant seal?
my cardomain
Old 01-22-2005, 08:38 PM
GringoEJS GringoEJS is offline
I agree with the coolant seals. You are going to need to rebuild the motor or put in another.
Old 01-22-2005, 11:59 PM
D3rELiC's Avatar
D3rELiC D3rELiC is offline
hows the smoke from the exhaust ? if its white or anormal then ur burning something that shouldnt burn
Old 01-23-2005, 04:41 AM
RevvRX-7's Avatar
RevvRX-7 RevvRX-7 is offline
Send a message via AIM to RevvRX-7 Send a message via MSN to RevvRX-7 Send a message via Yahoo to RevvRX-7
I have the same problem with my 86
"Hand to hand. It is the basis of all combat. Only a fool trusts his life to a weapon."-Grey Fox -Gray fox (Metal Gear Solid)
"There is no good,there is no bad.Just perspective and opinion."-Squall Leonhart(Final Fantasy VIII)
"Love.. it is just an illusion which weakens and imprisons us."-me
Old 01-23-2005, 04:51 AM
D3rELiC's Avatar
RevvRX-7 : before or after your dad took it for a ride ? lol
Old 01-24-2005, 04:45 PM
ghostrx7's Avatar
ghostrx7 ghostrx7 is offline
Send a message via AIM to ghostrx7 Send a message via Yahoo to ghostrx7
Sound Like A Rebuild To Me, My 94 Fd Had The Same Problem And Mazda Checked Everything 5 Times Before They Figured It Out! Good Luck
Old 01-24-2005, 07:46 PM
fcdriver fcdriver is offline
Ok you need to have your coolent system pressure checked to see if you have a seal bad, but like everyone else has said that is what it sounds like but it's nice to know for sure before you tear into an engine for a rebuild.
Old 01-24-2005, 08:50 PM
try this when engine is cold. open rad cap fill up your rad to the max, then disconect the injector fuseand crank the engine. if coolant splashes out you have a blown coolant seal.
my cardomain
