Originally Posted by bdivin
How do I remove the front door panels? I got everything off except for the area around the door latch. I could not find what was holding it. Please advise.
You will have to take off the bezel around the outside of the door handle and lock unit. shove a flat head screw driver into the slot between the top of the lock and the bezel, push screw driver downward gently. The top of the bezel should now be free. Then do the same b/t the bottom of the handle and the bezel, this time gently pushing upward. The bezel should now be free, just move the bezel out around the handle-you will have to open the handle to remove it. This should free up the door panel minus disconecting the eletrical lines of course.
