Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 01-22-2005, 03:22 PM
FlyingDaggers FlyingDaggers is offline
Question Need major help w/ installing an alarm system
I need assistance of installing an alarm security system in my 94 prelude 4ws. Which set of wires under the dashboard do i use to connect w/ the alarm's wires???
These are the wires that i'm having difficulties understanding----
Black/White---Open Dormer (o/p -500mA)
White/Blue----Engine Cap (o/p -500mA)
Green/Black---Rolling Up Windows (o/p -500mA)
Red/White ----Trunk (o/p -500mA)
Blue-----------Food Brake Switch (i/p +)
another thing is that somehow it did not come with the shock sensor---how will that be a problem in the future??? How do i fix that problem or prevent that problem.???
Please someone help me with these issues.....ur assistances is greatly appreciated....
XKz
Old 01-22-2005, 03:34 PM
civicnation425's Avatar
civicnation425 civicnation425 is offline
Send a message via AIM to civicnation425
Re: Need major help w/ installing an alarm system
not sure on the rest of it, but not having the shock sensor wont do much. a person can bump into your car now and the alarm wont go off. or a gust of wind wont set it off.
It is a catch 22 on having one or not, its nice feature, but it can be an annoyance at times. But no problem if you dont have it.
1995 Civic EX
AEM RAI
Magneflow Catback
Plugs/Wires
Coil-Overs
Just the basics...
Old 01-22-2005, 03:52 PM
Another question came up------
for the Yellow wire to says goes to the ignition coil-----do i have to get the Yellow wire from the alarm system and add an extension to the Yellow wire and drag that wire to the engine----ignition coil--??? or where can i find a closer ignition wire??? Does the key ignitor work???
I"m all confused----dats y i'm doing all my research b4 i fried my lude----can't afford the pros-----
Thanks for all who'd helped---
Xkz
Old 01-22-2005, 04:36 PM
riccimangan riccimangan is offline
No offence my friend but if you have to ask these kind of questions your probably better off getting the pro's to do it for ya,.,., Your relying on the word of people you don't no, if they get it wrong you could f*ck up the alarm and its your pocket that suffers not ours. All alarms are different and the chances of finding someone who can describe accuratley what goes where with your one are slim.
oh well thats my advice anyway,
Maybe if you post the make and model number of the alarm you'll find someone who has the same one,.,.,.,.,.,
good luck!,.,.,.,.
Old 01-22-2005, 04:45 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Ditto for above. I do alarms for a living and sorry but your kind of questions make me uneasy to answer them.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 01-22-2005, 05:04 PM
Re: Re: Need major help w/ installing an alarm system
Well----here's the model----
Model: LD 168 Series
Option Group
FCCID: QNMWA168
349925
the wire colorings on the alarm is quite different from the car's wiring. Will a wiring diagram for the 94 lude help determine which wires goes w/ wat wires.???
I will do the research until i know for sure i won't be able to do it----then save for a pro---but in the meantime--i will do as much research as possible--b4 handing it over to the pro's.
thanks
Xkz
Old 01-22-2005, 08:23 PM
1gspot's Avatar
1gspot 1gspot is offline
Send a message via AIM to 1gspot
I hope I am not giving you enough rope to hang yourself with....
Wire Color Polarity Location
12volts white - wht/yel + steering column
Notes: Also located at the factory security plug located to the left of the steering column. the plug is gray in color. There is a black wire in the factory security plug that is a ground.
Starter black/white + steering column
Ignition blk/yel - grn/blk + steering column
Power Lock black/white - pass. kick 10 pin plug
Notes: Peel back foam on kick panel to locate harness
Power Unlock black/red - pass. kick 10 pin plug
Parking Lights+ red/black harness at fusebox
Door Trigger black/white - inst. cluster plug
Notes: Located in gray 14 pin plug above hood release handle in far left corner of underdash.
Trunk/Hatch Pin green/black - inst. cluster plug
Tachometer blue AC r.shock at test plug
Brake Wire green/white + brake sw. or fuse box
Horn Trigger blu/red - blu/blk - steering column
NEW HOMEPAGE
http://www.cardomain.com/id/1gspot
Old 01-26-2005, 06:49 PM
I'm pretty good with electronics and that even confused me, good on you for trying though,.,.,.,
Old 01-26-2005, 08:30 PM
For the person that has an idea on vehicle electronics, it's actually pretty easy. It's when you have a problem is where pros like me stand out.
Pioneer 4900mp
Orion C63 Coax rear
Old 01-27-2005, 12:24 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
The crucial thing about alarms is to get a good installation job done on them. I myself would not even think twice about having a professional install an alarm for me. Not that I'm some wiring and electronics guru, but shit looking at alarm installs makes me queasy.
Empty Pockets Racing Member #1
Old 01-27-2005, 04:04 PM
The hard part of installing the alarm is finding which wires goes w/ wat wires from the alarm to the vehicle.....i'm just having trouble determining the color wires on my 94 prelude to go w/ the alarm i bought--on ebay---
Options Group <----this is the alarm brand.....it comes w/ everything....
anyone knoes....please help a brother out---thanks---
peace----
Xkz
Old 01-27-2005, 04:20 PM
1gspot's Avatar
OK you are dumb, i just gave u the codes for all the wires in ur car. look in the manual that came with the alarm that lists the wire color and its function, then hook it up to the wire that has the same function on ur car. making sure polarity and what not are correct.
NEW HOMEPAGE
Old 01-27-2005, 07:42 PM
1gspot----if u are a smart-ass...then explain to me why there are 2 wires of the same color coding----??? every fawken wire is double----
remember.....don't mock other peeps just bcause u were born a bastard n raise an ass---
Old 01-27-2005, 08:56 PM
1gspot's Avatar
ok hmmm let me see how i can describe this, when u look in the book there should be a diagram showing which wires coming out of the brain control what, if there are two of the same color look at either which colors are next to it or which harness its on coming out of the brain. if u have any more questions talk to me on AIM. And sry for flaming before but i get frusterated when i describe something as clearly as i can and people dont get it
NEW HOMEPAGE
