Old 01-22-2005, 03:18 PM
steyr911 steyr911 is offline
Send a message via AIM to steyr911
supercharging the 3800
ok, i have a 2000 camaro with the 3800 series II. now i was sitting around the shop the other day and somebody said that chrysler was cutting costs on its amplifiers for speaker. apparently the 250 and 500 watt amps are the same thing, just a small factory solder acts as a switch between the two. so i was thinking, maybe GM is doing the same with their motors. there are alot of 3800 supercharged, adn alot naturally aspirated. so i was wondering if anyone knows if you could just bolt on a super and not have the engine blow up in like 2000 miles. i know usually you have to swap out pistons and stuff like that, but if i dont have to, then im definatly going to super that thing LOL. thanks!
Old 01-22-2005, 04:17 PM
Shinigami2x4 Shinigami2x4 is offline
6 psi is a safe measure, i once heard these motors can handle 9 psi with normal wear and tear with, but more then that requires new things, and upgrades.
Old 01-22-2005, 11:34 PM
6 psi? is that what the supers on most of the stock 3800's are running at? (like the grand prix gtp's) one more thing, how much horsepower can i look to gain with 6-7 psi? and is the computer on my car gonna go crazy with it? thanks for posting!
Old 01-23-2005, 07:14 PM
turbo ES turbo ES is offline
Re: supercharging the 3800
dont GTPs have around 230 or 240 with a supercharger
Old 01-23-2005, 07:16 PM
A 6 psi supercharger is able to give almost 80-100 hp. The gtps have a different type of supercharger, if you get the powerdyne blower supercharger, makes more power.
Old 01-23-2005, 07:24 PM
MMonnier2302 MMonnier2302 is offline
The new SS monte's and impalas make 280. They got same engine. And they are fast as hell. ( ridden in one)
i love dem bats!!
1995 Camaro Z-28
2000 Dodge Ram 4x4 Sport 5.9
Old 01-23-2005, 07:25 PM
oh i thought that sounded a little weak for that much boost
Old 01-23-2005, 09:45 PM
hey thanks everyone for replying! so basically any 3800 motor can handle a super then right? the old GTP's had 260 hp, adn the new ones have 280. but that was just an example. i just wants to know whether or not i can make this thing super'd without swapping parts. thanks again!
Old 01-23-2005, 10:27 PM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
A '04 Impala SS can beat a '00 GT mustang....I will testify to it...(but then it is a mustang....)
Old 01-24-2005, 10:09 AM
Yeah the GT's are overrated
i love dem bats!!
1995 Camaro Z-28
Old 01-26-2005, 06:27 PM
philly rs's Avatar
philly rs philly rs is offline
Send a message via Yahoo to philly rs
correct me if im wrong but i was thinking about doing that to mines and without building up the engine i found that for the money you put into that project you werent going to get much of a gain at all. all my buddies have v-8's some supercharged and one with a turbo and for the boost you could get without bombing the engine in a 3800 they told me it was a wast and just spray it (which im now about to do) i dont think your gonna get much gain out of a 3800 with a turbo, or a s.c. unless u do the buildup. but the bottle never fails... 100 shot on a stock engine as long as u aint doing it all the time i found to be ok and u get alot of boost!
Your import sounds like my ass after a night of mexican food..
And spraying aint cheating, its brining a gun to a knife fight!!
yeah, its a v6 RS...never mind the f1 badges lol
HYPSI87 u will be missed
Old 01-26-2005, 08:32 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
GTP supercharger is not worth the time effort and moeny to swap, would be much better off getting for example the Powerdyne kit. There are also turbo kits out there. IIRC the powerdyne can bolt right on and it, gives 6 psi boost but of course building up the motor wil give more power andmore peace of mind.
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 01-26-2005, 09:15 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
those gtp's and ss supercharged monte's area actually low 15 high 14 sec cars... not extremely fast. but they feel real fast to the uneducated...
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 01-27-2005, 06:04 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
you cant just throw forced induction onto a motor that wasnt designed for it. first of all, you cant just bolt on a GTP charger. from my understanding, the two setups (grand prix and the like and camaro) are completely different. not to mention the cost involved in matching up computers and harnesses and sensors. plus you would need to build the rotating assembly to handle the higher temps and pressures associated with forced induction.
if you want a charger for your 3.8 i believe (but am not sure) that there is a bolt on system out somewhere. if you want i can try and find it or you can just run a search to find one...
*Better power-to-weight ratio than a C6 corvette*
Old 01-27-2005, 08:47 PM
eh, ok. well, you guys convinced me outta it. im not gonna super the thing. its got 70K miles on it right now, so thinking about it makes me wanna say nah. methinks the thing will die around 200K, and by then ill have the money and know how to rebuild the thing, or swap in a v-8. thats the big question now (after it dies of course)... drop in the v-8, or rebuild the 6 it has in it now, 'cept with enuf performance parts to make it FAST. my astronomy teacher at school has a 87? grand national with a decked out 3.8 that runs 9.8's. so i dunno. sleeper camaro? haha. but then again, v-8's just plain sound and feel better. opinions?
