Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 01-22-2005, 03:47 PM
JOnEB4EvR JOnEB4EvR is offline
Send a message via Yahoo to JOnEB4EvR
Squeaks/Grinds on Right Turns
Anyone got any clue what I gotta do to get rid of the noise?
Squeaks/Grinds around front axle only when driving and the steering wheel is turned clockwise even a little.
It seems like its something with the suspension, but if I turn the steering wheel clockwise, go outside and bounce the front end, there's no noise. Could it be something with the steering system?
2003 Ford Focus ZTS
Old 01-23-2005, 08:55 AM
ZX2000 ZX2000 is offline
Re: Squeaks/Grinds on Right Turns
sounds like a busted axle/cv...
Old 01-26-2005, 10:00 PM
focusyn focusyn is offline
Re: Re: Squeaks/Grinds on Right Turns
I second that idea, have a reputable shop check out the constant velocity (C/V) joint. I say reputable because C/V repairs are not cheap and you don't want anyone gouging you if thats not the problem.
But having this problem with an Acura Legend, I believe you have a C/V joint problem. This part is suffers lots of stress in any vehicle, but it's even worse on a FWD car because the steering puts additional strain on it.
This is not an easy part to break. If it is broken, either a C/V boot has a tear in it( which lets moisture in and wears the C/V joint quickly) or the car has been abused.
Old 01-27-2005, 12:02 PM
nose-gobblin's Avatar
nose-gobblin nose-gobblin is offline
Send a message via AIM to nose-gobblin
aye, it could be but you might notive this move when driving, there might be a small piece of dirst stuck in a seal in the power stearing box, you will be surprized what dirt can make for noises. Other than that you might was to grease the fittings, if there are any, in the front suspension, There could be a million differnt things, this is a problems that is hard to diagnose without dribing.looking at the automibile
2001 Ford Focus SE LIMITED EDITION.
-Laser Red
-5 Speed Manual Trans.
-Fully Loaded
-XM Sattelite Radio
-APC Euro Tail Lights
-JVC Deck w/ Motorized Face
-Falken ZE512 205-50-r16 91v
-Interior Glow Lights
Old 01-28-2005, 06:30 AM
rwd does not have C/V's...
Old 01-28-2005, 08:42 AM
Mustangman25's Avatar
Mustangman25 Mustangman25 is offline
Send a message via AIM to Mustangman25
??? We're talking about the Focus here...FWD...and I'm pretty sure that RWD cars that have IRS have C/V's but someones free to correct me on that if I'm wrong...
-Chuck
Old 01-30-2005, 09:36 PM
where did rwd come from?
-Laser Red
-Fully Loaded
-XM Sattelite Radio
Old 03-05-2005, 11:27 PM
well the boots are fine, and nothing is loose under the hood that I can find. i can't figure what else might be wrong... i just read about a wheel bearing being loose... might have to check that out.
2003 Ford Focus ZTS
Old 03-06-2005, 07:49 AM
^^^implies rwd has c/v's... c/v's are only necessary when you have axle's (fwd) that need to expand/compress/hinge when your front wheels are turning. rwd does not have c/v's because it doesn't have fwd axles... and the c/v is ON a fwd axle for that specific purpose. they have nothing to do w/ the actual steering of the car.
You don't have to lie to make friends... keep that in mind next time you post.
Old 05-11-2005, 12:00 PM
msavage2000 msavage2000 is offline
Creaking sound too?
I am experiencing a creaking sound coming from under my ZX3 when I turn to the right. There is hardly any creaking when I turn to the left. The creaking noise occurs as I turn right and the suspension travels over bumps or vibrations in the road. The noise doesnt occur when I shake the car or turn the steering wheel side to side when I drive straight. It doesnt appear to be a driveline problem or brake problem either.
It seems to me that I have either a loose exhaust hanger or connection that is creaking or some suspension bushing or component, spring/strut noise, or engine mount noise. I will be diagnosing it this weekend to see what it is and follow up with post.
Thanks,
Mike
Old 05-11-2005, 03:49 PM
Sounds like it could possibly be a CV joint...CV's are what allow the axle to move with the suspension, hence the creak, and right side CV's always go first (on LHD cars at least) due to the fact that you always take right hand turns much sharper then left in normal driving.
-Chuck
