Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 01-22-2005, 02:03 PM
blueyes47 blueyes47 is offline
engine light on
my son has a 95 T bird the engine light came on last night and I don't know why it stays on. Everything seems okay, oil, temp, etc.
Old 01-22-2005, 05:11 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Re: engine light on
First off, low fluids or an overheated engine will not cause a check engine light to come on. A bad sensor related to emissions will. Take it to autozone, pep boys, a ford dealership, any shop that can read the codes causing the check engine light. Once we know the codes, we can help, assuming the shop doesn't fix whatever is wrong, but we need codes and possibly the circumstances when it comes on.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 01-22-2005, 05:50 PM
solaris=amazing's Avatar
solaris=amazing solaris=amazing is offline
Re: engine light on
Plus..Autozone does it for free..
Old 01-22-2005, 07:23 PM
Re: engine light on
I should also add that 99% of the time driving a car with the CEL on will not leave you stranded beside the road.
Old 01-22-2005, 07:50 PM
Re: engine light on
Blueyes47, start the car, and put it in reverse. Give it a HAIR of gas. If it stalls, or is jerky..it's most likely the Mass air flow sensor.
This happened to me, this also happens in drive-if you give i alittle gas-it wants to die. Hopefully it's only that, cause it's under $100 to fix.
Go to autozone, scan it..
If you need a maf sensor, go to www.directauto.com
Old 01-23-2005, 12:19 AM
Re: engine light on
And if it sputters and misses constantly it could be egr related and if the CEL comes on after 5-10 minutes of driving it could be an O2 sensor and if you have to constantly give it a little gas at a stop light 'cuz it won't idle it could be your TPS and if.....
