99 ZX2 wont start!!! Weird buzzing
Can anyone please help me??? I put in a new intake the other day, and it ran fine. Than i was given the bright idea of disconnecting the battery to reset the computer so I can use the intake the best. Well, I reset the comp, and now my car wont start. When I turn the key, it turns over just fine, but never starts up. And now when I turn just the radio on, I am getting a buzzing sound from a part that is underneathe whrer the air filter goes. Its a part that has a bunch of wires connected to it, if anyone would need the part number I could give it to them. Anyways, also when I turn the radio on, my rpm gauge goes all the way on, I dont know if this is significant, but I thought I might mention it. Hmmm...what else, oh when I reconnected the battery termonal, i broke off the nut that keeps on the neg wire, but like I said, im getting power, so I dont think this is the cause. If anyone can help me I would really appreciate it.
Rich |
Re: 99 ZX2 wont start!!! Weird buzzing
Did reconnect the MAF (mass air flow) sensor or any other little sensors that might be put in the intake path?
2003 Chevy 1500HD - Hauler 1971 Chevy Camaro RS - Track Car User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here. |
Yep
I did put the sensors back in, the MAF, if that is the sensor that looks like a little light bulb inside a ring,that one isnt as far in the intake tube as it was, but it still is in, so I dont think that is the problem, plus, it was running fine before I disconnected the battery.
explain the buzzing? if the nut isn't tightened on the - terminal you might not be getting a good ground. that doesn't explain the buzzing though. ive heard of buzzing if you switch the wires though. make sure you got + to + and - to -. push the plug for your MAF in as hard as you can to make sure it's all the way in.
Fords go nuts with anything other than a perfect ground (negative) Seen wierder things caused by just that.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
Re: Re: 99 ZX2 wont start!!! Weird buzzing
Almost like demon posession. New cable, all issues solved. Might not be your problem, but it was worth mentioning.
Hey Rich and/or others,
Did you get up and running? I am having a very similar problem and was wondering if you could share how you got it running again. Also, the sound I have is more of a loud constant ring under the dash - was yours similar? Thanks |
