Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 01-22-2005, 12:07 PM
jtsbaker jtsbaker is offline
Angry 2000 ls engine stalls at idle
engine will stall at idle sometimes computer shows both o2 sensors are running lean any help on the fix would be ggggggggggggreat
Old 01-22-2005, 12:52 PM
robTypeR robTypeR is offline
Banned
Re: 2000 ls engine stalls at idle
could be alot of things checdk ur injectors make sure they are clean
Old 01-22-2005, 02:40 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
check for intake leaks.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 01-22-2005, 07:39 PM
fry628's Avatar
fry628 fry628 is offline
the problem is probably a leaking PCV harness that is located under the intake and is very hard to replace. It is a rubber elbow that goes into the pcv.
Certified Ford tech for 10 years
