Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-22-2005, 12:56 PM
snow_angel_777 snow_angel_777 is offline
Send a message via MSN to snow_angel_777 Send a message via Yahoo to snow_angel_777
Angry 97 dodge ram 1500
My truck starts fine but once it gets warmed up and you hit the gas my oil pressure drops to zero and the oil light comes on. then when you let off gas to make a stop or slow down truck dies and the oil pressure comes back up also when you let off the gas. it restarts easy after dieing but need to know what is wrong with it any Idea??????
Old 01-22-2005, 01:01 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: 97 dodge ram 1500
Is there oil in the motor?
My Mopars
Old 01-22-2005, 01:04 PM
Re: Re: 97 dodge ram 1500
yes the dip stick shows it is full
Old 01-22-2005, 01:10 PM
BleedDodge's Avatar
What size engine? How many miles?
My Mopars
Old 01-22-2005, 01:15 PM
it is a 318 with a 129thousand miles on it
Old 01-22-2005, 01:28 PM
we did a code check on it and it came up with a code 32. Also oil on dip stick has a gas smell to it and seems to be over full now
Old 01-30-2005, 12:04 AM
Bear Claw Bear Claw is offline
Gas in Oil
Sound Like you have bad rings. Looks like a engine rebuild will be needed.
Including Heads rebuilds also.
Old 01-31-2005, 03:46 AM
MoparMurphy MoparMurphy is offline
Sounds about rebuild time. The oil pressure could surely indicate worn main and rod bearings. Gas in the oil would be from bad rings and could be thinning the oil enough to cause the loss of oil pressure to be amplified. A basic rebuild kit comes with everything you need to refresh the motor shy of the machining of the cylinder bores.
Old 02-01-2005, 02:05 AM
BleedDodge's Avatar
Code 32 has to do with the EGR system. It might be something as simple as a bad vacuum line, causing a bad vacuum leak. That would explain the stalling.
I'd put a new EGR valve in it, and have the rest of the EGR system checked.
My Mopars
