Old 01-22-2005, 11:41 AM
fiercecivic's Avatar
fiercecivic fiercecivic is offline
Send a message via AIM to fiercecivic Send a message via MSN to fiercecivic
troubleshooting anyone?
I have a 95 dx coupe with a d15b7, last night I took my g/f and a couple of friends to the theatre, bout 45 minute drive. After about a half hour there are some steeper hills. when i got to the top of the first one my heat guage went up to about 3/4, so i pulled over to cxheck it out. there was antifreeze all over the fanhousing etc. but there was still lots of antifreeze in the rad. Nowe even though it was that hot my fan wasnt running. My guess was the temperature was roughly -23c, and i had four adults in the car. On the way home it did the same thing but when i dropped the two people off it sat around 1/4 to 1/2(usual running temp). This morning i checked to see if there was antifreeze in the rad, and yes there was but the overflow tank was near empty. I started the car up to check for bubles thinking it was a blown headgasket or cracked head, but there were no bubbles. The antifreeze was flowing slowly out of the top but there were no bubbles... this has me stumped. I left the car running for 15-20 minutes and the fan did not turn on. the temp out today is -18c. Would a dead fan motor create these symptoms?? can anyone help. thnx
sorry for the long story
Old 01-23-2005, 01:13 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: troubleshooting anyone?
check the radiator for cracks and leaks. check the overflow for cracks and leaks. check all hoses for cracks and leaks.
if you suspect the fan motor, check it for resistance and continuity.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 01-25-2005, 10:29 PM
thepig333 thepig333 is offline
Send a message via AIM to thepig333
I would try flushing your radiator and then adding some water weld after you filled it back up. I had a similar problem and added the water weld and never had the problem again. I found the stuff at walmart
1994 Honda Civic SOHC VTEC
Current Mods : AEM CAI Intake, APC Front and Rear strut tower bars, Neuspeed plug wires, B & M Short Throw Shifter, SS blaster Coil, MSD distrubitor cap
Plans : Flow Master, Eibach Dampers,Eibach Sportline Springs, , MSD SCI Ignition System, Throttle Body Spacer
Dreams that are too expensive right now : Headers, Cam Adjusting Pulley, Connecting rods, light weight pulley system, Racing seats, 17" Konig Holes and toyo tires
Old 01-26-2005, 09:46 PM
snowman2005's Avatar
snowman2005 snowman2005 is offline
Send a message via AIM to snowman2005
thermo switch?mayb if ur saying it aint turning on
ive got manuals
92-95 civic 96-98 Civic
clicky here clicky here
WTB:92-95 EX/SI cluster w/tach
FS:*NEW* 92-95 civic coupe black floor mats(4). pm me for pics or offers
