Old 01-22-2005, 10:36 AM
EVOclipse EVOclipse is offline
Send a message via AIM to EVOclipse
crankshaft pulley bolt
Does anyone know which way to turn one of these to get it loose? its on a 1.8 mitsu motor? thanks
240sx, soon to be S13.5, future mods are wheels and hopefully paint and the rest of my conversion.
(96 eclipse RS 5-speed, magnaflow exhaust,chrome headers,cold air intake,denso iridium sparkplugs,new kumho tires )******EDIT totalled car now*******
Old 01-22-2005, 12:11 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: crankshaft pulley bolt
On all of the 2 liter motors it turns the usual way, counterclockwise. I would expect the 1.8 to be the same. But its set to 80 foot pounds, and can be a bitch to get off. Its easiest to loosen it when the tranny and motor are still in the car, so you can put it in gear and use the tires to hold the motor. I've also put a breaker bar against the ground and bumped the starter to break it free, but try that one at your own risk If the motor is on a stand, I stick a bar in the crank counter weights if the oil pan is off, its I dont want to remove it I put two flywheel bolts in the crank and put a bar between those. Etc.
Edit> For the sake of using proper terminology, the crank pulley is what drives the accessories, and is held on with 4 12mm bolts. The large center bolt holds on the crank sprocket.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-22-2005, 12:15 PM
GotGrip666's Avatar
GotGrip666 GotGrip666 is offline
Banned
you need a special clamp thing to pull the actuall pulley right?
Old 01-22-2005, 12:54 PM
robTypeR robTypeR is offline
Banned
lol u guys are all wrong it turns the same way as every other bolt exept u need one thing IMPACT GUN if u dont have one all i gotta say is GL its not gonna come off only way to take one off is with an impact
Old 01-22-2005, 01:03 PM
GotGrip666's Avatar
Banned
um you can insult my intelligence but gsxracer knows way more the you do about 4g63 and its sad that your little honduh witht the turbo setup cant beat our midly upgraded turbos gs-t or tsi dont matter , and sorry if im coming off wrong but it seemed like you were trying to be a smart ass
Old 01-22-2005, 02:35 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
i took mine off without an impact. hell i pulled the whole engine without any air tools. damm that was a pain in the ass. i thuink i broke it loose with a 3/8 rachet with a 6 foot long pipe on the handle. that was back when i barely had any tools. fun times.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 01-22-2005, 03:15 PM
AF - Advisor
I have an Impact gun, and I have never used it for the crank sprocket bolt. I save it for the bolts that are actually hard to get off And no one said it turns the other way, so I don't know who you are talking to when you say "u guys are all wrong."
Kevin Jewer
