Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 01-22-2005, 09:00 AM
livwir livwir is offline
Angry Heater fan stopped working!
I have a 99 ZX2, bought it new. It has about 98k on it now. I had the a/c on back in the summer, turned it off, shut the car off for about 5 minutes and when I started the car back up the fan wouldn't work. I didn't worry too much about it when it was just a/c, but it's too freakin' cold to go without it now. Any ideas on what happened? Is there a fuse for the fan that I don't know about?
Old 01-23-2005, 07:44 AM
ZX2000 ZX2000 is offline
Re: Heater fan stopped working!
did u check the fuse box? lol... there's 2 of em. one's in the engine compartment in front of the battery and the other is right under your dash-light dimmer...
Old 01-23-2005, 11:17 AM
Dodgeboy57 Dodgeboy57 is offline
i have had the same proble recently where niether a/c or heater worked , i turned my car on and it works again i dunno??????
Old 01-23-2005, 03:35 PM
Re: Re: Heater fan stopped working!
Yep, checked the fuse boxes. There is one labeled ROOM, but it isn't blown. I checked all the fuses and none were blown. I popped the radio out a little and felt up in there to see if there was a wire off the back of the switch, no good there either. I guess I'm going to have to either freeze or take it in and have it looked at.
Old 11-12-2008, 12:31 AM
dabb95 dabb95 is offline
you may want to check your blower. I had a short on mine. When someone would touch it with their foot it would quit working bump it again and it would start
Old 11-13-2008, 07:45 PM
rhandwor rhandwor is offline
Use a volt meter and check for 12 volt to the blower motor. It can also be a bad resistor but should run on full power.
Old 11-15-2008, 05:44 AM
Davescort97 Davescort97 is offline
Escort guy
The post you replied to is almost 4 years old. I doubt that they are still looking for a solution to the problem. start a new thread rather than resurrect a thread that is over 3 months old.
