4X4 problems
I have a 1990 s10 blazer 4.3 I just got I started to hear viberation every so often usally after a loud clunck so I replaice the right front bearing do to got worst sounds like a single engine AIRPLAIN hahaha but it still makes the noise but not in four wheel as often and sounds like the four wheel kicks in but there is no difference tracken can some one please help
Re: 4X4 problems
When you replaced the bearing did you torque it properly? (180 ft pounds preload) Secondly, to check if you are actually in 4wd is to throw it in 4wd then drive in a tight circle in wheel lock and see if you hump the road. If you're not, your front diff isn't engaging.
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
Re: 4X4 problems
not really sure about the torque and I have tried to work the four wheel on dry pavement including making a U turn there is one other thing I forgot to put the spacer ring on the shaft didn't relize it intill today and gona fix that today
Re: 4X4 problems
If you don't torque it to 180ft punds you will end up destroying the bearings fairly quickly...
Re: Re: 4X4 problems
Re: 4X4 problems
could it have been that side anyways?
Re: Re: Re: 4X4 problems
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal Last edited by rlith; 01-22-2005 at 02:38 PM. |
Re: 4X4 problems
that's good to know , so does that sound like the problem? or do you think it could be something else ?
Re: 4X4 problems
You're not gonna know until that hub is properly torqued down....
If you did you can really strain your trucks drive system and do a lot of damage. This might have caused some of your problems. I only use 4x4 when I need it, and I haven't needed it yet this winter. |
Re: Re: Re: Re: 4X4 problems
Re: 4X4 problems
me Mooron |
