Old 01-22-2005, 07:37 AM
BiGwiLLswiLLy BiGwiLLswiLLy is offline
Send a message via AIM to BiGwiLLswiLLy
which motor
merlin or gm crate motor? with would you think is best a 502 gm crate or a merlin 454 crate for the same price...the gm is 502 horse n torque but was gonna change a few things before i dropped it in or the merlin with about 604 horse...but no more can be done to it fully built...
Old 01-22-2005, 07:39 AM
its goin in a 69 camaro..set up with a 400 trans with trans brake 3500 stall speed converter reverse pattern shifter, 12 bolt rear 4:53, spool, and 33 spline axles...
Old 01-22-2005, 10:23 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: which motor
Merlin all the way.
Old 01-22-2005, 05:22 PM
MMonnier2302 MMonnier2302 is offline
Thats going to be an animal of a car!!!!!!!!!!!!!!!
I'd say the GM Crate because they're more common, and probalby a longer warranty. Also if you ever decide 600hp isn't enough, you'd have to go forced induction for more power. i'd do the GM because simple bolt-ons would make crazy power on a 502. You'd put yourself well past 600 horse after a little money.
i love dem bats!!
1995 Camaro Z-28
2000 Dodge Ram 4x4 Sport 5.9
Old 01-23-2005, 07:12 AM
CORE402's Avatar
CORE402 CORE402 is offline
Re: which motor
Either way is a good choice. But if I had to.... Hmm. I would go for the 502 GM motor. Just because of its greater displacement. However, the Merlin probably has better heads, the blocks are cast a little thicker for added strength and better cooling. The World block is going to be a better made engine, but for price to power I would go for GM 502. If money isn't an issue go for the Merlin block.
1973 Camaro
AFR 195cc heads
CNC Motorsports 383 short block
Comp Cams hyd flat tappet
TH350
Dual 3" exhaust (LOUD)
Corporate 10 bolt w/ all new internals and axles
Old 01-26-2005, 06:33 PM
i was lookin at the merlin cause it actually has a better warranty n is dyno tested n tuned already...
Old 01-26-2005, 06:35 PM
the 502 i was lookin at is the best one they make...i figured i could work that motor a lil more but then i realized for the money i put in it i could buy a bigger merlin engine around 700 or more horse so im thinkin merlin
